07-31-2014 09:12 AM
Hello. My EOS 1Ds Mk II has a problem. The rear control dial doesn't seem to work, in that it never changes any setting in shooting mode. In all other respects it works fine, but in M mode for instance, the front control dial changes shutter speed but the rear does zilch. Likewise, flash exposure comp., regular comp. both don't work with the rear dial. Am I missing something? The on/off switch is on, but the camera behaves like it's off. The dial DOES work for menu selection and moving around the menus.
Am I missing something? I've reset all custom and personal setting, reset the date/time clock, and the firmware is current.
07-31-2014 11:27 AM
I agree. Send it to Canon service. I think they still work on the 1Ds Mk II but not the 1D Mk II.
07-31-2014 11:40 AM
07-31-2014 11:18 AM
The switch to the upper left of the dial must be set to 'ON'. Otherwise the dial wil not work.
07-31-2014 11:20 AM
Yep, as I said, it's on. I'm thinking the switch is defective. Makes sense.
07-31-2014 11:27 AM
07-31-2014 11:32 AM
Say, I never checked this, but if you have your 1Ds handy, can you navigate the menu system using the rear control dial with the switch off?
07-31-2014 11:38 AM
Just a minute. I'll get it.
07-31-2014 11:39 AM
Yes I can. You know you have to keep the Menu button pressed?
07-31-2014 11:40 AM
Yep, mine works that way too. It's definitely the switch.
07-31-2014 11:44 AM
These are wonderful cameras! The pixel pitch is big and the prints are fabulous. They capture stuff the mega MP cameras can't and are not even close. I mostly shoot with the 1Ds Mk III now but the 1Ds Mk II is a very fine camera.
07-31-2014 01:24 PM
@ebiggs1 wrote:These are wonderful cameras! The pixel pitch is big and the prints are fabulous. They capture stuff the mega MP cameras can't and are not even close. I mostly shoot with the 1Ds Mk III now but the 1Ds Mk II is a very fine camera.
Yeah, but as some wag once put it, all of the 1D series are about the size and weight of a paving stone. I'm sure they're great on a tripod, and I do see people carrying them around. But at a fast-paced event where you generally need two cameras and at least one big lens, anything heavier than a 5D seems pretty much unthinkable to me. Just sayin'. ![]()
