02-25-2024 08:38 PM - last edited on 02-26-2024 02:50 PM by Kristoff
I have a CFast card reader, Imac pro with Sonoma 14.3.1 OS and it does not recognize the card, even if in the camera.
02-25-2024 09:22 PM
Bradley,
Have you researched whether your camera is compatible with CFast cards.
I also read that CFast 2.0 readers are not backward compatible with CFast 1.0 cards.
Steve Thomas
02-25-2024 10:16 PM
it is and it will not read when in my camera either, it used to but I updated my OS on my iMac, now it doesn't recognize a cfast card
02-25-2024 10:34 PM
Bradley,
I wish you all the best, but I'm afraid I won't be able to help.
I really don't know anything about CFast cards or Macs either.
Maybe you could reach out to Canon Support, or to other owners of the kind of camera you have.
Let us know if you ever get your problem solved.
Steve Thomas
02-26-2024 08:26 AM
@bwalley wrote:I have a CFast card reader, Imac pro with Sonoma 14.3.1 OS and it does not recognize the card, even if in the camera.
I am assuming the reader connects via USB. Have you authorized the USB connection for the device in the Security section of System Settings?
02-26-2024 02:05 PM
Yes, it can read the CF cards fine.
Thanks,
Bret
02-26-2024 02:09 PM
Thanks for joining the conversation, bwalley!
So that the Community can help you better, we need to know exactly which camera model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
02-26-2024 02:30 PM
@bwalley wrote:Yes, it can read the CF cards fine.
Thanks,
Bret
It's a dual card CF & CFast card reader or is it the camera? Sounds like you have a 1D X Mark II?
So the computer sees the CF card but not the CFast card?
02-26-2024 02:39 PM
Yes it is a 1dx MKII
Dual Card reader, I record .jpeg to the CF card, RAW to the CFast card, the reader is a multiple card reader, the CF cards are reading fine, the CFast is not, I can't even download or see the RAW files on the CFast card when the camera is hooked up to the computer.
I have an iMac Pro and recently upgraded the OS to Sonoma.
I looked for updated drivers for the 1Dx MKII, but can not find any.
02-26-2024 02:51 PM - edited 02-26-2024 02:53 PM
What specific card reader are you using (make, model)?
I have never used CFast cards. In my external LaCie SSD drives, they have three card readers built into them: SD (UHS-II), CFast 2.0 and CFexpress. These drives are connected to my Mac Studio via Thunderbolt 4.
My last computer was an iMac Pro where I had attached LaCie hard-drive based drives that had built-in SD (UHS-I) and Compact Flash readers. These were connected via Thuderbolt 3.
And while I cannot confirm if there'd be issues with CFast, I have used SD (UHS-I and UHS-II) along with Compact Flash in these readers without issue.
