EOS-1D Mark III Unable to set ISO below 200
harryset
Canon 1D mark III, canon EF 24-105 IS, 1:4 L lens.  I am unable to lower the iso below 200 even with the CFN settings set  Max H, Min 100.
7 REPLIES 7
Waddizzle
Do you shoot RAW?  Which noise or image correction settings are enabled.  I think that one of the correction settings restricts the ISO range at the low end.
I shoot RAW and keep all correction settings disabled.
The OP most likely had “Highlight Tone Priority” enabled. When this is enabled the camera underexposes the shot by a stop. Therefore ISO 100 cannot be set.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
I don’t know if that older camera has that setting.  I have one, too.  It’s turned into a paperweight with an uncharged battery.
That camera has that setting so does my EOS 40D those cameras were both released in 2007. But a couple months apart. The EOS 40D was released in August of 2007. A lot features in the EOS-1D Mark III were in the EOS 40D. Such as the External Speedlite control menu.
-Demetrius
Peter
It sounds like HTP, as already mentioned. There's no benefits to using that if you shoot raw.
There may be little benefit, but it does change how the image data is written to the RAW file. In effect the camera uses a different "curve" when digitising the data to convert the signal level to a stored value in the RAW file. Shooting the same scene in RAW with HTP on and off gives slightly different results.
Brian
  • ISO 100 in the metadata is changed to ISO 200
  • The metering is changed to underexpose 1 stop
  • The MakerNote tag Highlight Tone Priority is changed from 0 to 1 or 2
  • The embedded JPEG will be brighter compared to the embedded JPEG at ISO 100.
For the raw file itself, I see no reason to shoot HTP.
ISO 100ISO 100
HTP ISO 200HTP ISO 200
DPP4 reads the MakerNote tag Highlight Tone Priority and will add a different tone curve for 0, 1 or 2.
RawTherapee will try to copy the tone curve from the embedded JPEG, so we can actually see what is happening in the post processing.
ISO 100ISO 100
Friends and Family
