Does AF setting carry across exposure modes?
Cantrell
Enthusiast
All,
I have a question about changing/programming Auto Focus. If you set the Auto Focus to 1Point in the FV mode does
that set Auto Focus to 1 Point in the other modes? That you for your responses.
Reese
Tronhard
VIP
VIP
Hi Reese!
I just tried this myself on the R5 which has the Fv feature in common with the other R, R6 and RP variants.
With the exception of the C1--C3 modes, changing the focus mode in Fv seems to change it as the default for other modes.  So, I change the mode in Fv and tried in in Av, Tv and M modes and got the same setting.  If I then set a different mode in one of those I got the same setting in all others except again for the C1-C3 modes.
I hope this answers your question, but come back if you need further clarification.
cheers, TREVOR
The mark of good photographer is not what they hold in their hand, it's what they hold in their head;
2 REPLIES 2
Tronhard
VIP
VIP
Hi Reese!
cheers, TREVOR
Trevor,
Thank you for your response. I could not tell from the material that I have read if you set a parameter in one mode it would set the same parameter in the other modes. Nice feature it will save time. I want to learn how to set up C1 and C2 so that I can utilize those mofdes.
Reese
Avatar
