09-05-2024
05:19 AM
09:55 AM
Can you help me? I have done some shoots recently with my R5 (with battery grip) in Manual mode and the Lock button engaged. I am using a Godox transmitter for lighting. However, it keeps jumping into Auto ISO. What am I doing wrong?
09-05-2024 07:49 AM
Greetings ,
Under your custom functions menu settings, please look at Safety Shift.
09-05-2024 07:58 AM
I hope some of this might be helpful.
There are several places in the camera menus that might cause the ISO setting to change automatically.
https://cam.start.canon/en/C003/manual/html/UG-03_Shooting-1_0070.html#Shooting-1_0070_2
Note
https://cam.start.canon/en/C003/manual/html/UG-08_Custom_0030.html#Custom_0030_1-7
Note
ISO speed settings] if standard exposure cannot be obtained.
Auto lighting optimizer enabled might cause the ISO to change.
Having a flash attached changes some of the behaviors. I do not use a flash often, so others could give a better answer.
I use Fv more than M, and some of the behaviors differ between the 2 modes even when none of the settings are auto in Fv mode.
Some of the interactions among camera settings have changed with firmware updates. The version of firmware in your camera might matter.
