09-16-2024 04:30 AM
Good day there.
Anyone knows how to enable the display of battery % on the R5MK2 when using the LP-E6NH? The camera don't have an issue with displaying the battery % when using the new LP-E6P. But when an LP-E6NH was used, the the battery % was not available and the Info icon was greyed out and the registration of the battery into the camera is not possible.
I don't have any issue with the R7, but it is not available on the R5MK2. BTW, the battery that is having problem is a Canon original.
Thanks in advance.
Jason
09-16-2024 10:35 AM
This is the behaviour of the EOS R5 Mark II with older non LP-E6P batteries.
The manual mentions it here https://cam.start.canon/en/C017/manual/html/UG-07_Set-up_0320.html
Make sure to expand the Caution note under the first section, it says…
09-16-2024 10:35 AM
09-16-2024 11:09 AM
Thanks Brian.
