Dark arch shadow on images
melmadden23
Hi! I'm trying to trouble shoot a problem I'm having with my camera.  There is a dark shadow-looking arch that is showing up on almost all of my images.  I'm having this problem with multiple lenses so I know it's a camera issue and not a lens one.  Has anyone seen this before?  Any ideas as to what is causing this?  Thanks for your help!
10 REPLIES 10
ScottyP
Hi Melmadden,
It sounds like what happens when the lens is casting a shadow with your on-board flash. Does it do this if the flash is definitely not popped up and firing?
The built in flash does not stand up high enough to avoid making a shadow with medium-to-long lenses, or with a lens hood mounted. You end up with your lens making a shadow puppet in your image. . You can avoid this by using a taller Speedlite flash unit, which will be high enough to shoot over the lens to avoid making a shadow. . Or stick to short lenses with no hood on when you use flash.
Could this be it?
Scott
It would be most effective if you could post up some sample pics.  Thanks!
melmadden23
Thanks for your replies.  I have attached a photo for your reference.  All of the images that this is happening were taken without flash.  Thanks!
ScottyP
Well, that is definitely not a lens shadow. A lens shadow would be on the bottom of the picture, it would be solid instead of an arch, and it would not happen without flash.
1.). You say it happens most of the time. So sometimes it does not happen?
2.). What lenses are affected? Are any lenses NOT affected?
3.). Does it only happen at narrow apertures? (Or only at wide apertures?)
Scott
I'm wonder if there isn't a "hair" on your sensor (technically there are two filters in front of the sensor so it's not really on the "sensor" but on the glass filter in front of the sensor.)
To test this,
1)  please set your camera to Av mode.
2)  Find a plain image with little to no contrast (the more plain, the better).  A plain white wall or white ceiling works extremely well.
3)  Set the camera to it's MINIMUM f-stop (run the main dial (top near the shutter button) the the lowest f-stop possible and take an exposure.  If your lens goes down to f/3.5 use f/3.5.  For this test if you are shooting a plain scene such as a white wall it actually does not matter if your subject is in focus or if the shutter speed is too slow to hand-hold the camera.... that's because we're not trying to study the scene but rather than shadow cast onto the sensor).
4)  Set the camera to it's MAXIMUM f-stop this will likely be f/22 but some lenses do f/32 -- again, but adjusting the main-dial (near shutter button) to the highest value.  The high f-stop will require a much longer exposure time.  Take an exposure.
Unload the images and look at them on your computer.
If the shadow is caused by something resting on the "sensor" (really the filter in front of the sensor) then you'll have a weak but broad shadow at low f-stops and sometimes it may be very hard to even notice that it's there.  But the image taken at a high f-stop will have a much more distinct shadow.
This can explain why you only see the problem in "some" images.
If it is on the "sensor" -- don't panic.  It's very easy to clean if you know how.
Tim Campbell
5D III, 5D IV, 60Da
Thanks for your replies.  Problem solved!  I brought my camera to the camera shop today and there was a hair on the sensor.  I did a little more digging into my images before I went to the store and found that it was happening only at high f-stops.  They were able to clean the sensor for me and I'm all set.  Appreciate your help!
This helped me so much. I have a Sigma Art Lens and I rarely use it because I thought it was broken.  Thank you!
Hi sorry that this is years old, but I'm having the same issue but instead of the black shadow on my images, it's on my videos. I'm using the Canon EOS Rebel T5. Any solutions? Thanks!shadow.jpg
You have a dirty image sensor.  It appears to be dust.  Do not touch it.  You want to use an air bulb blower to clean the sensor.  Do not use your mouth to blow inside of the camera, either.
BTW, I think the person who started the thread actually has a failing shutter, not a dirty image sensor. The fact that it only shows up at certain shutter speeds is telling.  Dirt on the image sensor does not care what shutter speed you use.
