R6 Mark 2; Only 3 shots for HDR?
photopro
Enthusiast
Went to Letchworth State Park in Oct. for the glorious fall colors in NYS as the spur of the moment so i packed lightly, taking a tripod the R6ii, 24-105rf, 2 ef lenses.  I got there kinda late and half of the canyon was in shadow so i knew i would have to shoot HDR to get the full range of exposure.  I thought the R6 would shoot the number of shots i set up to 7, for HDR composting.  WRONG!!  it only does 3 shots unless you wanna shoot 7 exposures manually which would be a real pain.  The HDR mode on the camera is probably inferior to using 5 or 7 RAW shots in high speed with a tripod.  I was sorely disappointed but also a little embarrassed that i didn't know this ahead of time thinking it was just like my 5d-4.
The camera has a drive mode with a timer that the number of consecutive shots can be set.  I thought this was for HDR but it either shoots the same exposure or the the limited AEB which is 3 shots.  So if you use that setting you get 3 with the AEB, and then AEB starts again if over 3 shots.  Useless for HDR.  What happened to setting the shots to 5 or 7 exposures?  3 shots is ok but i always shoot 5-7 to get the full range depending on the scene.  Gonna look at the images saved by the camera but i think 5 shots is needed for the best most natural HDR shots.  If i have the opportunity to go back next week i will certainly take the 5d for HDR, and the R6 for everything else.
Anyone else screw up like me?
2 REPLIES 2
Waddizzle
I dunno. I haven’t used in-camera HDR for at least a decade. I always shoot RAW and AEB with the shutter delay timer. Drive mode must be Continuous Drive   The camera captures the entire AEB sequence automatically.
Yes same for me.   i have never used it until i didnt have a choice.  The method you described is what i expected to do on the r6 like the 5dm4. That will only get you 3 shots.  Interesting the setting for Timer Continuous is manually adjustable from 2 to xxx. But it only duplicates the aeb pattern you have input automatically using the high speed shutter.  So 2 gets you 2 sets of the same HDR aeb exposures (6 total shots).  I don't know what the purpose of that is....  I have only used 5 to 7 shot HDR images, never 3.
