DSLR 600D turns off suddenly
pixelUnator
Hello,
I have a Canon DSLR EOS 600D, in a really good condition, no damages nothing. It turned off suddenly few days back, I ordered a new battery to check if it’s a battery issue, but it’s not. The camera still wasn’t turning on. Yesterday, I discovered that, when I keep the turn on/off switch to ‘on’ for few minutes/hours while having the battery out, it turns on when I connect the battery back in while the switch is still on, but after 3-4 seconds, it turns off again.
As the device is out of warranty, canon service Center is denying to repair it, and there is no good local repair shop around me either. I tried cleaning the charging points but still won’t work, what must be the issue, can I solve it myself in any way?
4 REPLIES 4
Arthur
Moderator
Moderator
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
ebiggs1
Besides a new  battery and SD card there is noting the average person can do to repair a faulty camera. It requires professional service. Cleaning contacts is almost always a waste of time. It rarely to never helps.
EOS 1DX and many lenses.
ebiggs1
BTW, keep in mind a good working used T7 is worth around $150-$200 bucks. So that is your top dollar repair price point.
Hi @pixelUnator,
We're sorry you are having issues.  Please know that Canon can't service your product, not because its out of warranty, but instead because its end of life.  Its 12 yrs old now and parts may not be readily available to repair it.
Ernie provided you a price point to be mindful of.  You can try checking with midwestcamera dot com.  They are a authorized Canon repair facility in Michigan.  They can sometimes service and repair older gear.  Not always, but you can check with them.
There is also a lot of certified used gear available on line.  KEH is a good source for this.  A newer used model might also be a good idea.
