04-02-2023 01:08 PM
I recently updated my R6MkI with the 1.8.1 firmware. I typically use the FV mode with the control ring programmed to control Exposure Compensation. Since the update this no longer works. Changing the control ring function to other settings such as ISO control and it works fine. Does anyone else have this issue? Thanks.
04-02-2023 01:43 PM - edited 04-02-2023 01:44 PM
Start by resetting the camera's main and custom menu settings to default. Now program the Control Ring to control Exposure Compensation and retest. Results?
04-02-2023 02:22 PM
That worked. Thanks for the quick help. I'll have to remember that for future updates.
Bill
04-02-2023 04:23 PM
Glad it helped.
04-24-2023 03:39 PM
Where do I find reset options in the menu. Cannot locate them. Cannon r6 running 1.8.1
Thanks
04-24-2023 04:25 PM
Reset Camera is located on the Setup (wrench, yellow) menu, first item on tab 5. Clear Customized Settings is located in the Custom Function (second from the right, orange) menu, last item on tab 3.
Bill
