‎07-11-2017 04:56 AM
I keep getting the message "busy please wait" when I try to clear all camera settings
‎07-11-2017 07:34 AM
Remove the battery, leave it for ten minutes, refit it and try again.
‎07-11-2017 01:47 PM
Thank you for the reply. I have tried this a few times without success. Thank you for your help, though. Kind regards, Karyn
‎07-11-2017 02:16 PM
I don't know which camera you have but if it is one with a removable clock battery then remove that as well.
If the clock battery is not removable then take the main battery out and leave it out for a few days, before refitting it remove the lens and the memory card
‎07-11-2017 03:00 PM - edited ‎07-11-2017 03:01 PM
Your memory card is probably bad.
‎07-11-2017 08:30 PM
Are you using a micro-SD card ?
‎07-12-2017 04:02 AM
Hi
Thank you for the responses. The camera is a 70d. I have tried changing the SD cards and lenses and I have taken out the battery. I am on holidays for the next couple of weeks. So, as it is still working and this is my only camera, I will take the advice to remove the battery, lens and SD card after my return. Hopefully, that will work.
Thank you all again and have a great day.
Kind regards
Karyn
‎09-21-2018 09:51 PM
‎09-22-2018 09:12 PM
No, sorry. Nothing has worked so far.
‎09-23-2018 07:57 AM - edited ‎09-23-2018 07:58 AM
@KarynHemming wrote:No, sorry. Nothing has worked so far.
I am sorry. With no reply, I assumed your issue may have been resolved. Try to reset the camera without the memory card inserted. You should also try to contact US Canon Support about your 70D, too. There has been a recall for certain types of failures.
