05-11-2025 02:37 PM
Hi, when I stills/photography mode I want to be able to just press the record button, to start recording slow motion video at 100fps. It always defaults to 25fps 1920x1080 😞
I am sure there must be a way to do this ?
Thanks
Mark
05-11-2025 03:00 PM - edited 05-11-2025 03:02 PM
I believe the default video settings, when pressing the video button, are stored in the Custom Shooting Mode 3 (C3). So you should be able to set your video the way you want it, then store it in C3. Then when in still and you press the vid button, it should take the settings stored in C3.
I'm pretty sure this is the way it works, but I don't shoot much video 🙂
Newton
Newton
05-11-2025 03:52 PM
Thanks that works !!
