07-12-2013 12:48 PM
I need to change the owner name in my faithful EOS 5D. As I understand it, this can only be done with the Canon EOS Utility. (Changing the camera owner name allows me to add the author name, also, in the event an image is processed without adding all of the valuable metadata.)
I'm currently using EOS Utility version 2.13.10. I CAN see my EOS 5D MKII camera with no problem, and I can edit the camera owner information.
Unfortunately, I can't see my 5D in the EOS Utility. I'm using a Mac Book Pro, running OS 10.6.8.
I can, however, shoot tethered in Capture One, but not Adobe Lightroom. We're all aware of the many combinations of cameras and software applications and their compatibilities - I've been chasing this for years.
So...does EOS Utility version 2.13.10 NOT work with a Canon EOS 5D? Do I have to revert to an earlier version to make this work?
Thank you.
07-12-2013 02:04 PM
Supported model for EOS Utility version 2.13
EOS 70D, EOS Kiss X7 / EOS Rebel SL1 / EOS 100D, EOS Kiss X7i / EOS REBEL T5i / EOS 700D, EOS-1D C, EOS 6D, EOS M, EOS 60Da, EOS Kiss X6i / EOS REBEL T4i / EOS 650D, EOS 5D Mark III, EOS-1D X, EOS Kiss X5 / EOS REBEL T3i / EOS 600D, EOS Kiss X50 / EOS REBEL T3 / EOS 1100D, EOS 60D, EOS Kiss X4 / EOS REBEL T2i / EOS 550D, EOS 7D, EOS-1D Mark IV, EOS Kiss X3 / EOS REBEL T1i / EOS 500D, EOS 5D Mark II, EOS 50D, EOS 40D, EOS Kiss F / EOS REBEL XS / EOS 1000D, EOS Kiss X2 / EOS REBEL XSi / EOS 450D, EOS-1Ds Mark III, EOS-1D Mark III
07-12-2013 02:04 PM
07-12-2013 02:31 PM
Well...that explains that.
Maybe I can still use an earlier version of EOS Utility with a 5D....?
Thank you.
07-12-2013 11:04 PM
The latest version of Canon Utility that supported the 5D is only compatible with OS X. But you can try.
09-02-2018 08:30 AM
You must have the WIA Driver installed for the 5D camera itself, otherwise most of the settings in the EOS Utility will be greyed out. Your computer will not recognize your camera in PC Connect mode without the WIA Driver. I used EOS Utility 2.4 for the Canon 5D.
