12-26-2018 08:28 PM - edited 12-26-2018 08:30 PM
I received a used canon rebel XT as a gift. I would like to change the owner name that is embedded in the digital information on each photo.
I have spent some time researching and it seems i need to make the change using the EOS utility or maybe ZoomBrowser. When i go to downloads for the RebelXT there is no EOs utility available.
I downloaded the utility for a different model, but the option to change camera settingss is grayed out.
How in the world do I change the information and/or get the proper EOS utility? I realize I can manually change the author name in the file info of each photo, but given the number of photos it would be much prefereable to have the correct name embedded to begin with.
Thank you for any help!!
12-27-2018 08:36 AM
12-27-2018 04:47 PM
Hello LSchaefer33,
Yes, connecting the camera with EOS Utility is the appropriate way to make the owners name change. However, the EOS Rebel XT is not able to connect to modern operating systems with the current versions of EOS Utility, which is why you do not see versions available.
It can connect in PTP mode to download photos but not through EOS Utility, instead you'd be using the operating systems built in imaging tools to establish a direct download more akin to how a card reader operates. If you have an old computer and prior versions of the software, it would be possible to connect the camera and enact the change.
12-28-2018 11:28 AM
Lightroom and possibly DPP4 can do this for you. It won't change the camera but it will correct the photos.
Metadata is a set of standardized information about a photo, such as the author's name, resolution, color space, copyright, etc., and keywords applied to it. To avoid file corruption in a Raw file, XMP metadata is stored in a separate file called a sidecar file. Other file formats supported by Lightroom, like jpg and dng, the XMP metadata is written into the files in the location specified for that data. You can set this as a preset and it will do it upon import without any action or input from you.
12-27-2018 02:16 AM
You have to contact Canon and see if anyone there has the original XT CD. Then you have to find a computer to run it.
12-27-2018 08:36 AM
12-27-2018 08:37 AM
12-27-2018 08:55 AM - edited 12-27-2018 12:00 PM
@LSchaefer33 wrote:
thank you that's helpful. I will do that if nothing else, so my son-in-laws name is not on all my photos!
Your son-in-law is the one who changed the name using the "EOS Utility" software on his computer. Take the camera back to him and have him change the name or delete it.
12-27-2018 10:47 AM
Call Them.
1-800-652-2666
12-27-2018 11:28 AM
12-27-2018 11:28 AM
12-27-2018 04:47 PM
Hello LSchaefer33,
12-28-2018 11:28 AM
