05-13-2020 03:45 PM
So I have a an older Canon EOS Rebel XSI. I just bought a new High Performance SDHC Memory Card 16 GB. No matter what I do I can't get it to work. I flip the notch on the side, up down middle so forth. It keeps saying Card write protected. I have probably had about 20 differnt cards in the last12 years. I never had it not work. I am unsure if it is states it is High performance or what. I personally think it is a bad card. Any suggestions?
05-13-2020 06:15 PM
Well I bought a new card. It worked. I think it was a bad card. Thankfully Walgreens took it back and refunded me.
05-13-2020 04:17 PM
Do other cards give the same error? If yes, then the switch in the camera that senses where the write protect switch on the card is positioned may be sticking. If not it would seem like a card problem. Can you put the card in a reader or a computer and try to format it?
SDHC is the key identification, which is compatible with your camera. Terms like High Perfromance, Extreme Pro etc are marketing terms.
05-13-2020 06:15 PM
05-14-2020 07:49 PM
@DriveByShooting wrote:Well I bought a new card. It worked. I think it was a bad card. Thankfully Walgreens took it back and refunded me.
Was it the same type of card? I might have guessed that a 16 GB SDHC card might be too modern for an XSI.
05-14-2021 10:30 AM
Yesterday, every card I put in the camera said it was locked, even though none of them were. If the switch in the camera that senses where the write protect switch on the card is positioned, is sticking, is that something i can fix?
05-14-2021 11:38 AM
@cbpick wrote:Yesterday, every card I put in the camera said it was locked, even though none of them were. If the switch in the camera that senses where the write protect switch on the card is positioned, is sticking, is that something i can fix?
I have no idea whether or not you have the skills to fix it. If you have to ask, then I do not recommend attempting it. Did you look inside of the slot for dirt or foreign debris?
