Canon T2i wireless shutter release
Gerryyy
Hi All,
I just purchased a Vello Freewave Plus wireless shutter release.  My only issue with it and my T2i is that there is a 10 second delay from when I press the remote shutter release and when the camera fire.  I believe it's something to do with the camera as the 10 second delay counts down in the lower right of the rear screen.  Any ideas of how to turn 10 second delay off?  TIA.
5 REPLIES 5
ebiggs1
Reset the camera.
Under the [wrench] tab, select [Clear settings], then press <>.
Select the desired setting.
To revert the shooting settings to the default, select [Clear all camera settings], then press <>.
To revert the Custom Functions to the default settings, select [Clear all Custom Func. (C.Fn)], then press <>.
 Select [OK].
Select [OK], then press <>.
Setting [Clear all camera settings] will reset the camera to the default settings.
You must be in the <P> or other Creative Zone modes to do this.
EOS 1DX and many lenses.
jrhoffman75
Check if this setting is enabled.
I did the clear over the weekend.  I think it solved my 10 second dealy.  Thanks for the tip.
Gerryyy
It wound up being the clear function that helped me.  Thank you for your suggestion.
Clear will wipe out all settings, so be sure to re-establish the ones you want. Particularly the one that won’t allow you to take photos without a card.
