Canon Rebel T6 Exposure Bar Error
Alex88156
Hey, guys. Every time I use my camera on manual mode, I can't adjust my exposure bar [the bar that goes from -5 to +5 or whatever number it goes to] with the radial switch. All of my photos are underexposed. Any suggestions
13 REPLIES 13
kvbarkley
VIP
VIP
What do you mean by "radial switch"?
In manual mode you need to adjust the shutter speed, the Aperture and the ISO to get what the camera thinks is a good exposure. All three of these need to be set in different ways: check your manual.
I suggest you fix the ISO at 100 and go out on a sunny day and use the "sunny f/16" rule to get you in the ball park. The exposure for a sunlight object at f/16 at ISO 100 should have a 1/100 shutter speed.
I think he means whichever wheel it is that sets the exposure compensation.
Bob
Alex88156
Yes that. Ok I'll try that
Which usually just sets one of the three handles for exposure, usually shutter speed. In manual mode you have to adjust all three.
I think you and the OP are talking past each other. I think he's asking how to set exposure compensation on the T6.
Bob
diverhank
You can't apply exposure compensation while in M mode for this camera.  Only a handful of Canon cameras allow you to do it in M: 1Dx (I & II), 5DMk IV, 7D Mark II are the 4 that I can think of.
Diverhank's photos on Flickr
On a T5, you can set exposure compensation in Manual mode, but you cannot set AEB.  I would expect the T6 to be similar.
Waddizzle
I think you need to learn about the "Exposure Triangle", as well as how to adjust ISO, Aperture, Including Shutter Speed, on your camera.  Instead of using "M" mode, try using "P" mode and using the Quick Menu screen to adjust exposure settings.
Why guess?
From the T6 manual. Driverhank is right - and I knew it too, the T6S is the same way.
You aren't missing much. Just set the exposure where exposure compensation would set it.
