Canon Rebel T5i not working with Feelworld Monitor
Clayjar
I have this Feelworld monitor I connect to my Rebel T5i so I can see what I am doing while filming video. Well it failed after a year and kept saying "No Signal" and I bought a new mini HDMI to HDMI cable. It worked for a few months. Then that failed with a "No Signal" sign. I thought it might be the monitor but I connected my daughter's phone to it with no problem. IT worked with my daughter's phone with it own HDMI cable.
I tried connecting my camera to my TV and still get No Signal.
I bought a new mini HDMI to HDMI cable. Brand new. No such luck. Still get a no Signal. Could it be that my camera's mini HDMI port no longer works? I tried using a very old G11 camera ands till get the No Signal.
Try turning wifi off.
6 REPLIES 6
kvbarkley
Up until you mentioned the G1 I was thinking that you damaged the HDMI port on the camera. If you don't support the cable it is easy to pull the connector from the PCB.
I suggest you send the camera to be looked at by Canon.
You might try to connect the cable to the camera and the monitor and wiggle it a bit to see if you get a connection.
Clayjar
A monitor doesn't record signal. It's simply a larger screen to show you what your camera is shooting or recording. I use it to have a better view so I can focus on on my subject and to show me what I am recording if I can't see my LCD screen on my camera.
Yes, I know.I got that tip from a Youtube video. I turned the camera Wifi off and it works now. Thanks.
You should keep Wi-Fi disabled most of the time, anyway.  If you are not actually using it, it is an extra drain on the battery.
Yeah. Good point. Normally I do, but I used it to transfer pictures to my iPhone while on vacation and left it on and forgot about it. SO all this trouble for past year because of a setting that has nothing to do with monitors.
Friends and Family
