12-29-2022 12:52 AM
When using the R7 time lapse movie mode, if you use a shutter speed of two seconds or longer with two second interval chosen. Will the camera skip frames because it's trying to take an image every two seconds, but the shutter could be open exposing one image for two seconds or longer. Or will if just use 2 second interval between each image no matter how long of shutter speed you have chosen?
12-29-2022 05:15 AM
The camera will faithfully fire the shutter at whatever interval you set. It is completely independent of shutter speed. It is up to you select an appropriate interval and shutter speed.
12-29-2022 07:17 AM
So you are saying that in Timelapse movie mode, if I set a 2 second interval and set a shutter speed of say 4 seconds. Then each shot will be four second long exposure, then wait 2 seconds and take the next shot without skipping frames? Reason I question that is because when you're setting up the camera to take Movie mode Timelapse you set the number frames you want taken, then interval between each frame. Then the camera shows how long it will take to take that many frames with the interval you selected and how long of movie clip it will create from those settings. So how can the camera know how long it will take to take that many frames if it doesn't take into consideration the shutter exposure time?
12-29-2022 08:56 AM - edited 12-29-2022 08:57 AM
@EVaughan wrote:So you are saying that in Timelapse movie mode, if I set a 2 second interval and set a shutter speed of say 4 seconds. Then each shot will be four second long exposure, then wait 2 seconds and take the next shot without skipping frames? Reason I question that is because when you're setting up the camera to take Movie mode Timelapse you set the number frames you want taken, then interval between each frame. Then the camera shows how long it will take to take that many frames with the interval you selected and how long of movie clip it will create from those settings. So how can the camera know how long it will take to take that many frames if it doesn't take into consideration the shutter exposure time?
I did not say that, at all. Let me repeat. The camera will try to fire the shutter at whatever interval you set. If you want to fire the shutter every two seconds, then your exposure needs to be completed well under two seconds..
01-27-2023 10:09 PM
"well under"? I shoot Milky Way timelapses with 8 sec exposures. Usually I set the interval at 10 secs, to allow each exposure to be completed. But can I set the interval at 9 secs with enough time for all exposures to be completed? Or even an 8 second interval? The manual is silent.
01-28-2023 01:13 AM
@EVaughan wrote:When using the R7 time lapse movie mode, if you use a shutter speed of two seconds or longer with two second interval chosen. Will the camera skip frames because it's trying to take an image every two seconds, but the shutter could be open exposing one image for two seconds or longer. Or will if just use 2 second interval between each image no matter how long of shutter speed you have chosen?
The shutter speed must not be more than or equal to the interval. If your camera is busy when the next shot is scheduled, like writing the previous shot to disk, the next shot will be skipped. At least that is the way it works in the R5 and 6, but I think that is pretty standard. I've tried the built in time lapse, but I use a MIOPS unit, and it works that way also.
Newton
01-28-2023 11:45 AM
Thanks for feedback, much appreciated.
01-28-2023 01:35 PM
@paulhummerman wrote:"well under"? I shoot Milky Way timelapses with 8 sec exposures. Usually I set the interval at 10 secs, to allow each exposure to be completed. But can I set the interval at 9 secs with enough time for all exposures to be completed? Or even an 8 second interval? The manual is silent.
Please note that I keep referring to the “exposure time”, not the shutter speed. This is because some of the Noise Reduction in the camera may extend the length of time it take to complete an exposure to up twice the shutter speed, or even longer as it writes data to the memory card.
For example, between High ISO NR and Long Shutter NR, one of the other will take the time to capture a second exposure using the original shutter speed to use as a reference for the NR algorithms.
This means your 8-second exposure can easily take over 16-seconds to actually complete!
I have run into this trying capture multiple images of the Moon in quick succession. If I get the timing incorrect, the camera will capture the first frame in the sequence, and then abort the entire cycle.
01-29-2023 08:06 AM
If you are experiencing issues with interval shooting, then I strongly recommend that you begin your own thread for your issue.
This thread was created by someone having issues with capturing frames for time-lapse movies, which is a completely different shooting scenario from your issue with capturing full resolution images using the built-in intervalometer. .
01-29-2023 09:22 AM
Thanks, helpful. I had not realized that NR lengthens the exposure time relative to the shutter time. On all 3 of my RP cameras I see that it was set to Standard. There doesn't seem to be an option to turn it off completely. Does the amount of extra "exposure" time is adds depends on the setting? Should I set it to "low" rather than "standard" to minimize this exposure lengthening issue?
