09-03-2023 06:39 PM
I'm at my wits end here. Got a Pixel 7 Pro a few weeks ago and it will not connect to my R6m2 to transfer photos except on the home wifi, which is useless as I'm heading off to Japan in a few days.
Used to connect no bother to my Huawei Pro 30 when I was out and about, but now it seems to think a password is required. When I used the Connect to EOS Utility to locate a password (which for some reason keeps changing? useless) and use that for the Wifi connection on my phone I get a connection but without internet so the pairing fails.
I've deleted Canon Connect from my phone, deleted the camera from Connect, reset communication settings on the R6m2...tried everything with a fresh start....and nothing is working. I can get a Bluetooth connection, but not a Wifi to import images.
What else can I do? Other than throw both blooming devices in the bin and get something else?!
01-23-2024 04:00 PM
I had a similar problem...was driving me mad...until I realized the problem:
My VPN was on.
Turned that off and it worked like a charm. Could that be it?
02-10-2024 07:34 PM - edited 02-10-2024 07:44 PM
VPN scenario. A VPN Client, either Google 1, Cisco/Meraki, Fortinet, Open VPN, etc would keep the Canon Connect App from working unless the client allowed split tunnel. Typically all traffic is send through the host.
In a split tunnel configuration, the endpoint is also allowed to communicate with devices on the local LAN. I've not used Google1, so am not sure what it does with traffic. I did note it allows communication with carrier installed apps, but this would not include the CC App by default and I'm not sure if exceptions can be configured. Turning off would be best as you found.
02-10-2024 07:41 PM
@shadowsports wrote:Greetings,
Huh! Yeah, what he said!
02-10-2024 10:43 PM - edited 02-10-2024 10:46 PM
Great photo. Sometimes that's just how I feel 😀
07-19-2024 11:52 PM
I'm running into the same problem with the Pixel 8 Pro and the R6M2.
This is not happening for me.
The camera displays its SSID name and password.
I can see the Camera widi ssid on the phone. But I can't connect to it since I don't get the password on the camera. All I see is on the camera is a message
Connecting via Wi-Fi... Please wait.
On the phone in the app, I have a message
Switching to a faster wifi connection. Connecting to camera.
Catch 22 without the password
07-20-2024 12:08 AM - edited 07-20-2024 01:27 AM
OMG!! THAT'S WHAT IT WAS.
I had Adguard VPN on.
Thanks!!! This was driving me mad. Interestingly, I have no problems connecting to my EOS RP with it enabled.
I have added and exception to the Camera Connect app to bypass routing the connection through Adguard rather than turning it off alltogether.
07-20-2024 12:26 AM
So VPN was an issue, at least for some. 🤗
