02-20-2022
11:45 AM
08:48 AM
Anybody else having this problem with the Canon R6 freezing up. It usually starts with the camera not focusing. Its also becomes none responsive to mode changes. The on/off button doesnt work. Opening the battery door shuts it off... but still doesn't fix it. Pulling the battery out usually fixs the problem right away. But again... not always and sometimes it take a few battery removals to get it back up and running.
This has happened while shooting both photo and video. It happens with different lenses. It happens with different memory cards. I can't recreate the problem on command. The camera works 99% of the time. But at least once a wedding shoot, over the period of 6 hours, It freezes up!
In the video below... I was attached to the Ronin gimbal. But it's happened just shooting photos and without the gimbal. Plus, when I open the battery door and try and turn the camera on/off... it still doesn't work. Has nothing to do with that.
I was on firmware version 1.4
I updated the firmware this week to version 1.5.0.
This problem has been happening for a long time... 8 months. Camera is less than a year old.
Again, at last nights wedding... it froze.
Here is a video that I recorded when it happened.
1. Focus isn't working. Both back button and touch.
2. Display freezes up. You can still see the audio working.
3. On/off doesn't work.
4. open battery door... nothing works.
5. Pull Battery
08-21-2023 04:03 PM
I'm probably going to have to send my R6 in too. I've tried everything including upgrading to latest firmware. I also have an R5 which works flawlessly. Anytime I shoot Video on the R6 the camera locks up after a short time and the only way to recover is to remove the battery.
08-21-2023 04:17 PM
Same here! New motherboard for r6. Sounds like a big prob. Mine in warranty - never really worked
09-22-2023 10:06 PM
I sent mine in today. I’m spending over $500 with shipping to pay to repair my R6 purchased in Feb 2022. I hope Canon makes this right.
09-22-2023 10:08 PM
I am lucky that in NZ our Canon cameras come with a standard 5-year warranty, and so far (touch wood) in 40 years of shooting with them, I have never had a Canon camera fail.
09-23-2023 02:24 AM
Still happening on my camera. I was in Tanzania for 7 days and experienced it 3 times.
Solution it to remove the batteries and restart. It seems this is a hardware issue that Canon is not acknowledging. Even after several firmware updates this issue is not solved. Canon does not want to replace the hardware from the users.
Has this been resolved in Mark ii?
09-23-2023 02:25 AM
Sending is not going to help IMHO. I had my camera replaced about a year since I bought it and faced problems. The replacement has exactly the same issue.
09-23-2023 02:58 AM - edited 09-23-2023 03:05 AM
It's hard to dispute there is a problem. Especially when posting the video that has over 1000 views and nobody says anything.
https://youtu.be/931iHksY1u0
On a compltely different side note, I've declared my R5 useless as I mainly shoot weddings. And the error 20 comes up about once an hour. Today 30 popped up. 30 is new... but it's just over a year since I bought it. I can't depend on it for a wedding shoot. I recently lost a ceremony kiss because of this error 20.
Sending it in. Estimate is $500usd to take a look and hopefully fix it! Arrrrrg.
On another side note... my R6 Mark II seems to be working correctly. Yeah Canon.... that's 1 out of 5 of my new mirrorless cameras I can't complain about. haha (3 R6's, 1 R6 MII, and 1 R5)
09-23-2023 09:10 AM
Make sure that you have wireless communications disabled. Enable airplane mode.
Also, if you are using third party lenses and/or mount adapters, then that could be the problem.
09-23-2023 01:24 PM
We're using the new RF lenses. 15-35, 35 and 24-70. Happens with all of them. Also happens with Canon adapter and thre rest of my stable of EF lenses.
Pretty sure it's not the lens or mount.
09-23-2023 01:36 PM
Same, it doesn't matter which lenses I am using.
I started labeling my batteries and narrowed it down to two batteries that my camera freezes up when using. Once I removed those batteries from the rotation, it stopped happening. The batteries are the new Canon direct from B&H, so not black-market or off brand. I would highly recommend rotating which batteries are in your camera when it freezes.
Now if I could figure out why my R6 freaks out sometimes when using off-camera flash. The ISO will change itself to auto and sometimes my strobes flash with a magenta hue.
Anyway, I hope this helps.
