Canon R6 Freezing Up Intermittently
llehmann
Enthusiast
Anybody else having this problem with the Canon R6 freezing up. It usually starts with the camera not focusing. Its also becomes none responsive to mode changes. The on/off button doesnt work. Opening the battery door shuts it off... but still doesn't fix it. Pulling the battery out usually fixs the problem right away. But again... not always and sometimes it take a few battery removals to get it back up and running.
This has happened while shooting both photo and video. It happens with different lenses. It happens with different memory cards. I can't recreate the problem on command. The camera works 99% of the time. But at least once a wedding shoot, over the period of 6 hours, It freezes up!
In the video below... I was attached to the Ronin gimbal. But it's happened just shooting photos and without the gimbal. Plus, when I open the battery door and try and turn the camera on/off... it still doesn't work. Has nothing to do with that.
I was on firmware version 1.4
I updated the firmware this week to version 1.5.0.
This problem has been happening for a long time... 8 months. Camera is less than a year old.
Again, at last nights wedding... it froze.
Here is a video that I recorded when it happened.
1. Focus isn't working. Both back button and touch.
2. Display freezes up. You can still see the audio working.
3. On/off doesn't work.
4. open battery door... nothing works.
5. Pull Battery
145 REPLIES 145
The frustration is very real. It would be nice if Canon owned up to design flaws in the R5 and R6 system and offered to do something about it for anyone who spent thousands to upgrade to their new tech.
Guys,
Has anyone tried the new v1.7.0 FW.  Its worth testing.  I don't have an R6 myself.  I started a feedback thread.
R6 New Firmware Release - v1.7.0 - Feedback Thread - Canon Community
I am pretty consistent with doing firmware updates and have the updated version and have even worse issues than before including entire sequences of images just simply not writing to the card because the system freezes & errors out. Assuming people are just simply not following instruction isn't actually a helpful resolution.
DhandaNot
Enthusiast
I have had the same problem. Earlier it was happening quite often. The local Canon tech helped me change the RF EF adaptor and then the problem was not seen for almost a year.
But now the problem has returned. I use EF 500 L F4 normally with a TC 1.4. Whenever I use 2 x TC it is frequent.
Looks like the power supply across the adaptor is the problem. Yesterday morning I was using just the R6 and 500L but faced the problem again.
My observation is that it happens when I am in animal tracking mode and have used the camera for sometime. It has problem focusing and later just freezes and switching off does not help one has to remove the battery.
I also use Battery Grip with the camera so not sure if there is anything related to that.
Tronhard
VIP
VIP
My first response to anyone having issues is to make sure they are using the latest firmware version for their gear.  In the case of the R6, the latest version is 1.7.0.  I have two R6 units and they both work flawlessly with that firmware.
Another consideration is what lenses are being used with the camera.  I shoot predominantly with RF lenses, but I have also used legacy Canon EF lenses, and Sigma lenses (150-600c and 60-600s) via adapters.  No issues with any equipment.  I am a wildlife photographer who shoots hand-held in available light.
cheers, TREVOR
Sent my R6 back to Canin after having tried everything. Was under warranty and entire motherboard needed replaced.  Now works!!  Test was the problem - faulty from day of purchase.
Hi Chris - That may be correct in your case, and I am very glad you had a positive resolution, but it is is not necessarily valid to extrapolate that to others' situations, in part for the reasons I mentioned in my post.
Using the latest firmware is a valid procedure for any camera or lens, and from any manufacturer.
cheers, TREVOR
Absolutely. It has been over two years now. I saw the problem within 2 weeks of purchase and there is no resolution yet. The local Canon support changed the RF EF adaptor and the problem was not seen for some time, but now it is back.
tseager
I've had the R6 for a couple years now and just began experiencing this issue, with the same equipment. I did happen to use animal tracking mode for the first time today, when using an RF 100-400 f/5.6-8, but did have the issue a few days ago. I don't recall what other lenses I was using when this problem first began to be an issue, but was the RF 14-25 f/4.0 IS or RF 24-70 f/2.8 IS
How is one supposed to get all these parts to try swapping?
The freezing issue as we can see from this thread is reported by several users here and other forums.
I have not seen one place where Canon have acknowledged it as a know problem or listed it as a fix in any firmware upgrade. They continue to behave as if it is fiction.
