09-06-2022 01:17 PM - edited 09-06-2022 01:46 PM
I googled it, found that a lot of people are getting bad, blurry images from an anomaly in the eye focus mode. A focus pulsing occurs when keeping tracking active in the animal's eye.
The video below, from 10:00 on onwards shows exactly this problem.
www.youtube.com/watch?v=0lmjC07v8yI&t=471s
In the Canon R6 manual it says that (ALL) EF lenses work with the use of the EF-EOS-R adapter. But nowhere in the manual does it report incompatibilities or focus issues related to the smart focus mode (eye focus).
drive.google.com/file/d/1RFP_2LmEDNksaPlnz7IiWuZjmFId8y2q/view?usp=sharing
Link with images of a 100% static animal and still the focus shows (pulsing)
09-06-2022 04:22 PM
Hello Trevor,
I photographed other animals, birds and lizards. I get every 20 images 4 or 5 sharp. With my old 5D mk3 I would never have such bad results…. In the images that I made available, the algorithm perfectly found the eyes of that animal, it's its own eyes, it's impressive, but the focus doesn't stay…… in the images in which the eyes were focused, the animal's body was not sharp! using f10 aperture!!! How is this explained? this insect's entire body should be in focus, it's a small insect!!! The depth of field is totally unrealistic!!
09-06-2022 04:25 PM - edited 09-06-2022 04:26 PM
If it is that bad then I would suggest the camera is not working to spec. I have one R5 and two R6 units and have used all of them with a wide range of Canon EF lenses without issue - see my profile for my gear list.
Without being able to see this in action I cannot offer any more information or context than I already have. I would suggest you contact Canon for support under warranty. You can call 1-800-OK-CANON to do so.
09-06-2022 04:44 PM
Hi Trevor,
If I disable the AI tracking focus mode and use One Shot or Servo the images are perfect !!! the focus stays on the focused point !! I don't think it has a problem with the R6 body. I bought it a few weeks ago. Other people report this problem too, I'm not a unique case.
09-06-2022 05:02 PM - edited 09-06-2022 05:03 PM
My comment about raising this with Canon tech support still stands. If this is an issue with the Canon camera you have of the model then they can best help you. This is a forum of volunteers who try to sort out issues that are not requiring a system change or repair. Unfortunately this forum can't do anything more to assist you - you need to talk to a tech support person.
I would recommend that when doing so you give Canon the full and detailed description of all of the situations under which you experience these issues, including specifics of subject types and settings. This will help them to help you by being able to gauge the range and scope of the situations under which you experience the pulsing.
If you want the best response to your issues, these suggestions are made to make your own experience more positive.
09-06-2022 05:20 PM - edited 09-06-2022 05:21 PM
@rascher wrote:Hello Trevor,
Hi Rodrigo.
Here is a screenshot of one of your images. The image data doesn't give the distance from camera to insect.
The insect head is nice and sharp but the body and tree trunk down from the head are soft.
I guess there are two possibilities - 1. f/10 does not produce sufficient DoF at that distance and focal length or 2. some phenomena is going on where during exposure parts of the image fall out of focus. I believe #1 is more likely.
AI Servo tracking is designed to identify and follow subjects as they move through the viewfinder. It does that by sampling the image and determining the location of a subject at points in time and predicting where the subject will be when the shutter actually opens. Your subjects appear stationary; the tree and insect look in the same location in all your images. It is possible that the camera is sensing its slight motion if you are touching the camera when you actuate the shutter and thinking that it is subject motion.
In any event, I would be using One Shot AF with spot focus on the eye bulge if I was taking those images. And I would check a DoF table to ensure that DoF was adequate.
09-06-2022 07:23 PM
@rascher wrote:Hello John,
I selected Animals mode. Animals are animals in general. The camera identifies the eyes of ANY animal, even a dragonfly
If that were true, then I suspect that you would never created this post.
09-06-2022 07:26 PM
Hi Rodrigo.
The camera appears to be angled above the horizon, which would only contribute to creating the impression that the camera is experiencing focusing issues.
In other words, the shallow DoF created by the long focal length and the distance to the subject is only being made to appear even more shallow because of the camera angle to the subject.
09-06-2022 10:19 PM - edited 09-06-2022 10:28 PM
Never let it be said I don't go the extra mile (in this case about 12km) for those with issues. I went to the zoo with one of my Canon EOS R6 units, and the Canon EF 100-400L IS USM MkII, attached via a Canon adapter, I also took along the Canon EOS R5 using the Canon EF 70-200L f/2.8 IS USM, attached via a Canon adapter - a lot of the time shooting in 1.6 crop mode.
I have uploaded all of the JPG images from each into shared folders on my MS Onedrive for your review - they are unedited in any way, and they number run consecutively to show I was not cherry picking results. You will see some images that are massively out of focus as I was waking the camera up from snooze mode, or inadvertently pressed the shutter while handling two cameras, and I don't consider those a failure of the focusing system.
A note on shooting conditions:
I was shooting hand-held in available light - some of which was quite dim, in a mix of outdoors and indoors.
In the case of Lemurs and reptiles also behind glass. In some of those images, the focus was fooled by the reptiles' ears pits just behind their eyes.
The giraffes and zebras were a challenge because they use camouflage to protect themselves so the focus system was occasionally fooled by the colouration patterns
The bearded tamarin I shot was deliberately in the darkness of the tree it was sitting in and the eyes were therefore in deep shadow.
The Howler Monkeys are almost black on black.
By doing so, I deliberately challenged the focusing system, and I did not expect 100% accuracy. Even under these conditions my results seem to be far in excess of the numbers that the OP has quoted.
I encourage anyone viewing this thread to check out the images using Canon DPP software to display the focus points - I don't use Lightroom, so I don't know if that will do the same thing.
I would be interested in your conclusions...
Canon EOS R5 Images and Canon EOS R6 Images
Please respect my copyright by not downloading for other purpose than to examine them in this specific context. After viewing them, please delete any that are on your computer.
If that is agreed then that leaves us with the thought that it is not a systemic issue - if I can get these results so should the OP or anyone else. Thus, that leaves us other alternatives for the situation:
a fault in the camera, in the focusing system (including lenses), or how the camera is configured and used.
09-07-2022 12:27 AM - edited 09-07-2022 12:28 AM
Trevor, did you notice in the OP's example Raw files that he was using the 200mm L with an EF 2X III extender? I examined all of the OP's Raw shots and thought, with the exception of a couple, they looked acceptable considering they were using an extender.
Personally, I don't get the same results with an EF extender (I just have the EF 1.4X III) on the R5 & 6 that I got on my DSLR's... Not sure why. I used it [extender] on the EF 100-400mm L II with the 7D II, 5D IV, and for a short period with the R5 & 6. I just got better IQ on the DSLR's using the 1.4X.
IMHO, the problem with the OP's provided shots is the 2X extender. As for the insect and to answer John, I've dealt with that species before. They are generally quite large, so f/10 probably wouldn't cover it, particularly at that angle.
Newton
09-07-2022 12:39 AM
Thanks Newton. I had not twigged on that. I have had a few health issues and not as observant as I would normally be, so thank you for that information. Absolutely, I think that the addition of the extender would have an impact on quality and your comment about the insect is also indicative.
This has been a developing story. Starting with the first general statement based on a generalization from a video of the R7 using a different lens under different conditions. The context we now have about the lens config of the sample is a challenge in its own right. The rather bald statement that this has happened with other situations has no examples. That was why I invested a couple of hours shooting with the lens (minus extender) and the R5 or R6 focusing system. I have no issues with the results.
I would be interested in your perspective, if you have viewed them.
