Canon R50 starting advice or tips
h1awke
Hi I've just upgraded from a DLSR 700D to a R50, it comes with the standard 18-45mm STM lens and I got the RF 50mm f/1.8 STM as part of a deal too.
What are some good tips or advice to start with as I've never used a mirrorless camera before.
Is the shooting process much different?
Are there some settings I need to dial in or should change before I start?
Is the standard 18-45mm lens any good?
Should I get a zoom lens if I'm shooting wildlife?
I'll mainly be taking it out on hikes but I'm hoping it will be ok for everyday use too.
Any advice is appreciated. Thanks!
1 REPLY 1
stevet1
h1awke,
)1 Download a copy of your User Manual in pdf format. It will make your life a whole lot easier when searching for answers to specific questions.
2) There are tons of videos online about How to setup the Canon R50.
3) Yeah, you probably will need a zoom lens if you want to shoot wildlife.
4) if you still have some EF lenses from your 700D, you can still use them if you get an EOS EF-R adapter. They run about $120.
Steve Thomas
