08-05-2024 02:03 PM
Hello, today I wanted to disable the camera + automatic sensor cleaning process, but when I turned the camera off and on, the camera started cleaning the sensor again. When I looked at the camera settings, interestingly, I saw that this feature was active. I made a few more tries and the result did not change. Firmware ver. 2.0 .
Is there anyone who has similar problems or encountered this phenomenon? Maybe someone has a solution.
Thank you.
Bora.
08-05-2024 03:43 PM
Are you using any custom shooting modes?
08-05-2024 03:43 PM
08-05-2024 04:03 PM - edited 08-05-2024 04:03 PM
Yes, the camera is in a custom setting and I haven't turned off sensor cleaning before. I just checked and sensor cleaning is disabled except for custom setting as you said. I saved the custom setting (cancel sensor cleaning) and tried again and it's fine.👍
