02-20-2022 08:49 PM
Hi Canon,
After installing firmware 1.5, I was having my R5 freeze regularly with animal eye autofocus mapped to back button focus. I installed firmware update 1.5.1 this weekend hoping it will fix the issue. I went out today to shooting some shore birds. My R5 locked up 3 times in a period of 1.5 hours of shooting, one of the three was was with error E70. In all three cases, turning the camera off/on fixed the issue; this is different from firmware 1.5 freezes, where I had to take out the battery to fix the freeze.
Please let me know if you need more information about the camera settings. I happy to share them.
Regards, Mo
07-01-2022 07:59 PM
I have since discovered that carefully cleaning all contact surfaces with 70-30 alcohol and a soft cotton q-tip... The lens and in the camera contacts as well as the battery grip if you have that as well. That seems to solve the problem. I had a couple more freeze-ups after 1.5.2. I did that I've never had another freeze up in many, many thousands of pictures
07-01-2022 08:12 PM
Were you getting a specific Err code or no code at all (or didn't notice)?
07-04-2022 12:01 PM
I have had freezing issue with my R5 since I purchased it September 2021.
1. It freeze with screen/VF flashing as if it was cleaning buffer. I was shooting speed skating aiming and waiting to shoot only at a turn, not following the skaters all the way. Shutter mode was multiple or multiple H. I was not even on H+ mode nor pressing shutter to long. I switched to use my backup camera and went back to the R5 after 10 minutes, it was still flashing. I turned it off and on, same thing. I had to take the battery out a few time to get it fix.
Gear: R5, EF 100-400 ii, Converter, Sony Touch CFexpress B, 128GB, SanDisk CFexpress B 128GB
2. Recently, it freeze more often. More frequent on slow shutter 1/40 - 1/60. It is very frustrating as i would miss the actions at sport events. The freeze had happened on both the Sony and SanDisk card, hence, It is not card dependent.
I am contemplating whether to take it for service but i can not deal with not having the camera for a lengthy time. I have not experienced these technical issue with my previous DSLR Canon cameras. I am seeking a solution to fix this issue.
Thanks.
07-04-2022 12:09 PM
Hi Lindat,
Has your freezing issue been resolved?
Thanks.
07-05-2022 05:58 PM
I've heard about and used this potential solution before, but still have had freeze ups. Less frequently with the latest 1.5.2 firmware.
This is not an acceptable solution for this issue and should not be marked as such.
07-05-2022 10:47 PM
Yeah, I'm not sure why that was marked as a solution. I had a friend also buy a brand new R5 and brand new RF 100-500, and they got a Err 70 lockup within their first few days. I somehow doubt their lens and camera contacts came dirty from the factory, and I have doubts that my contacts have any dust, debris or other connectivity issues because I rarely change lenses and use my camera in fairly sterile environments.
07-05-2022 11:00 PM
Short version of my experience - my R5 had freezing issues that got progressively worse. Sent it in to Canon after 1st month and they returned it saying they found no issue. Spent 6 mths trying to figure out any settings, lens etc that may be causing issue. I could never find a root cause. Sent it in to Canon again & they said main board was faulty and replaced it. Seems to be working fine now but I haven’t had it back very long. My conclusion, Canon is aware of this issue and struggling to find a solution. The camera HW seems to have a design margin or quality control issue with many cameras working ok and some that freeze. It’s likely that people with persistent issues need a board replacement.
09-13-2022 10:22 PM
Well it seems like Canon has finally acknowledged my issue was a real issue and fixed it with new firmware for the RF 70-200:
Firmware Version 1.1.1 incorporates the following fix: 1. Fixes an issue, in which, in rare instances, "Err60" is displayed if zoom operations are performed when the camera is started.
As I thought, it was an issue with the lens itself and had nothing to do with my R5.
02-21-2023 07:10 PM
I'm on version 1.7 and it was very upsetting and embarassing to be on a corporate shoot today and have my camera freeze up 3 times! The first two times I tried to shut it off but it wouldn't, so I had to pop out the battery. The 3rd time, I got a black screen with a couple of diagonal red and white stripes and then a message came up telling me to shut it off and pop the battery! This definitely needs to be fixed!
02-22-2023 12:08 AM - edited 02-22-2023 12:09 AM
This thread is in regards to the R5 and FW 1.5.1 and 1.5.2.
You are using FW 1.7.0. If you'd like assistance, I would suggest starting your own thread. Since there hasn't been anything definitive as to the cause, please include the steps to reproduce the issue. Information about the hardware you are using when it happens and any other observations you believe is relevant. This will make it easier for others who might be in the same situation or able to offer assistance.
