03-18-2022 02:06 PM
I was using my camera no problem a couple days ago and I pick it up today and I only see black thru the viewfinder. Is there maybe something I hit or set that would cause this. It is the Canon R5
03-18-2022 02:35 PM
If in doubt, do a settings reset and see if that makes a difference.
03-18-2022 02:13 PM
First off, I would check page 777 of your user manual. You may have changed the settings.
03-18-2022 02:34 PM
I wish that was it! Any other ideas?
03-18-2022 02:35 PM
03-18-2022 03:26 PM
I did that and I have a screen now! Thank you!
03-18-2022 03:30 PM
Glad to help! 😊
Perhaps mark this a resolved, then others with the same issue can know where to look.
03-18-2022 04:07 PM
For future reference, the setting for that is "Screen/viewfinder display" in the Wrench 3 (yellow) menu. That will allow you to set which display to use, or auto switching.
Newton
03-18-2022 04:47 PM
Yep, as described on P777 of the user guide - as already indicated. 😶
01-06-2024 05:08 PM
Thanks for posting this. I am new to the community. This was a quick solution. Like her issue, the camera viewfinder setting changed between uses.
01-06-2024 07:43 PM
The manuals for Canon cameras are amazing resources. If there isn't a printed manual that came with the camera, you should download it and find out all that it tells you.
