04-13-2024 12:36 PM
04-13-2024 12:44 PM - edited 04-13-2024 12:45 PM
A show? Any lasers there? And would you mind sharing a raw sample?
04-13-2024 12:54 PM
No lasers. I've shot at this venue about a dozen times with the R3. Just typical lighting but no lasers.The photo above is from a video I took showing the electronic viewfinder kind of whacking out with the lines. It started happening about 2/3 of the way into the event last night. I immediately thought it was the CFExpress card and swapped it out with no affect. Currently importing the photos to my macbook. Took a photo on my phone of an affected image. Can upload a couple of RAW images later, if needed.
04-13-2024 01:44 PM
Yes please. Share one or two raw samples.
04-13-2024 02:01 PM
All three below if you bring up shadows you'll see the banding horizontally. This is what is showing in my manual and LCD viewfinder. This just started last night in the middle of the show. Definitely a sensor issue. Just have to find out how severe and if I can repair this via Canon.
04-13-2024 02:14 PM - edited 04-13-2024 02:19 PM
Never seen that before. It is not laser damage because it moves around.
There is also a vertical line in the masked pixels with no signal at all. I don't think R3 should have that.
04-13-2024 02:22 PM
I had an issue about a year ago with these lines showing up on photos but I think it was a bad CFExpress card. Swapped the card out and hadn't had any issues until last night. These lines appear on the digital and manual viewfinder even if there's no card in the camera. I've placed a service request in with Canon and will try to mail it out ASAP. Afraid that it'll be the sensor that needs to be replaced.
04-13-2024 02:25 PM
Also, below is video I took of what I see on viewfinder.
04-13-2024 02:49 PM
Please update us how things go.
04-13-2024 09:42 PM
At another show tonight. Used the camera just to test other cards which I formatted. Suddenly the tweaking out like you see in the video stopped and the camera now works fine. No idea what is up 😂
