08-11-2024 10:59 PM
Hello, I have a Canon R10 and have been taking some real estate photography where AEB is needed. I have AEB set up, and it takes the 3-5 photos with the different settings. Doesn’t it then merge those photos into one combined image within the camera? There must be some setting I am missing, I have looked everywhere and cannot seem to find it. Or is post processing the only way to combine the images? Thanks all!
08-11-2024 11:49 PM
You have just selected bracketing, that does not do any in-camera merging. What you want is HDR backlight mode:
08-12-2024 08:57 AM
08-11-2024 11:49 PM
08-12-2024 04:25 AM
In addition to Kevin's valuable input…
HDR Backlight Control is one of the SCN modes on the EOS R10, but if you want more control and use M/P/Tv/Av/Fv modes then you can also use HDR Mode on the second page of the red menus. This will take a series of three photos, and can be set to save a single JPG image that the camera creates from the three files, or save the three files. Individual images can be saved as RAW or JPG.
08-12-2024 08:57 AM
Thank you!!
08-12-2024 08:59 AM
Thanks! I think I need to move up to an R6 or R7 to get that feature. Appreciate it
08-12-2024 10:07 AM
My EOS R10 has that feature. You need to select M, P, Tv, Av, Fv mode for it to appear in the menu
