Canon EOS R7 - How to Choose H or H+ Shooting Speeds
RIG
On my EOS R7 when it is drive mode and shutter mode mechanical, I can't choose H or H+ shooting speeds. How can I solve this problem?
My problem was that the camera wasn't letting me choose H or H+ in the mechanical shutter mode.  It must have been a setting I choose in another menu that blocked the choice.  I just solved the problem by doing a complete reset.
12 REPLIES 12
Tronhard
VIP
VIP
Hi and welcome to the forum:
I don't have an R7, but I have read and researched quite a bit on the subject.  To get to use the H and H+ shutter speeds, you seem to need to switch to electronic shutter.  At that point you should be able to get to up to 30 FPS.  I recommend you review your manual and look specifically for references to shutter speed and electronic shutter.
cheers, TREVOR
Tronhard
VIP
VIP
I recommend you check out this review of the R7 by respected wildlife photographer, Duade Paton:
HERE
cheers, TREVOR
Waddizzle
You need a USB Type C male to USB Type C male cable.
I think this post actually refers to another thread Bill.
cheers, TREVOR
Hazel_T
Hi RIG,
The H and H+ drive modes are available on the EOS R7 when it is in mechanical shutter mode. There are a few things that the camera needs to use the H+ mode. Those are listed on the manual page HERE and I've included them below as well:
  • H+ enables approx. 15 shots/sec. continuous shooting speed when set to [Elec. 1st-curtain] or [Mechanical] under these conditions.
    • Room temperature (23°C/73°F)
    • Using any of the following power sources
      • Fully charged LP-E6NH (note that continuous shooting speed may become slower when using batteries with weak recharge performance)
      • Household power outlet accessories (sold separately)
      • USB power adapters (sold separately)
    • Shutter speed: 1/1000 sec. or faster
    • Flicker reduction: None
Thanks so much for that clarification! 😊
cheers, TREVOR
One of the Noise Reduction or Image Enhancement settings restricts your range of available ISO settings at the low end.  It might Highlight Tone Priority.  Disable all of them if you are shooting RAW.
I am guessing you had the Auto Level feature turned on. When that is turned on, you cannot choose H or H+ in mechanical shutter mode and cannot choose EFCS at all. You can choose electronic shutter and still get H and H+ though.
Friends and Family
