11-02-2022 07:48 AM - last edited on 11-02-2022 08:46 AM by Danny
hi
i tried to use sigma art 18-35 with canon R to shot slowmotion film 100fps but it doesn't work , i need high frame rate ,is there solution ??
11-02-2022 04:54 PM
The Sigma lens mentioned is an APS-C lens. The EOS R doesn't support high frame rate with APS-C lenses.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
EOS 40D & 5D Mark IV
430EX III-RT & 600EX II-RT
11-02-2022 08:54 AM - edited 11-02-2022 08:58 AM
The 18~35 should not have an issue used with the EOS R as long as you are using a Canon Adapter or Control Ring. The camera can shoot 1080P @120fps
Maybe the card you are using isn't fast enough? (Guess)
What "doesn't work"?
~CarePaks Are Worth It
11-02-2022 09:20 AM
option (high frame rate ) it doesn't work , it's gray and it's asking to change to movie cropping , when i try to change it ,it's give message (not available with the attached lens )
11-02-2022 04:54 PM
-Demetrius
11-02-2022 08:25 PM
Demetrius' answer should be marked as the solution. He's correct about the Sigma 18~35 f1.8 "DC" which is APS-C and cannot be used except in crop mode.
