10-03-2014 06:43 PM
I bought a 3rd party BG-E14 grip. When grip is attached to camera, the shutter dial on camera won't work. If I turn off grip power, shutter dial on camera works. If I removed the grip, the shutter dial on camera works as it should. Does anybody have this problem. It seems like the grip is sorting out the camera shutter dial. When the grip is attached & power ON, the shutter dial on the grip works fine.
10-06-2014 09:50 AM
" It seems like the grip is sorting out the camera shutter dial."
It probably is. 3rd party grips are usually a bad idea. Stick with Canon brand. Do it before this grip ruins your camera.
10-06-2014 10:09 AM
@ebiggs1 wrote:" It seems like the grip is sorting out the camera shutter dial."
That sounds a tad alarmist to me. I think it's a bit far-fetched that a crappy grip will ruin the camera. I suspect that in this case "s[h]orting out the camera shutter dial" actually means "fooling the camera's firmware into allowing it (the grip) to preëmpt that function."
Which doesn't mean that the grip shouldn't go back where it came from. A crappy grip is a crappy grip, and sticking with the Canon brand makes sense to me.
I don't believe in grips anyway. To me a grip is just a costly way to add weight and bulk for rather little benefit.
10-06-2014 10:53 AM
"To me a grip is just a costly way to add weight and bulk for rather little benefit."
You got part of that right. It does add a lot of weight but "little benefit"? One thing to remember the grip comes off. Just as easily as it goes one. When you don't need it, remove it.
When I had my Rebels, I had grips for all of them. The extended battery life is amazing and I could send a 2nd out for a day's shoot without fear of battery drain. Plus they did not have to contend with swapping out the battery, or losing it. And the vertical shooting position is better.
I no longer have any Rebels but all my 1 series come with a grip more ot less as they are. Once you go 1 series, you will never go back. They are something special.
10-09-2014 06:12 PM
well i have a real bg-e14 and have a slight issue.
it seems i was useing wireless and tured it off. after my shoot i could not syinc with a usb cord it was tring to set up a wireless connection but the camrea wirelss was off. to fix the issue i had to remove my battry pack and restart the cmarea not the grip but battry pack. i have used wireless before i got the grip and did not have any issues with syinc . any insight will be good on this issue
10-10-2014 11:16 AM
" any insight will be good on this issue"
Yes,
... it isn't the grips fault!
10-11-2014 01:45 PM - edited 10-11-2014 01:46 PM
@joe_okura wrote:well i have a real bg-e14 and have a slight issue.
If the camera is attached by a USB cable to a computer, Wi-Fi can not be set (Troubleshooting, EOS 70D Manual, Page 426).
Is it possible that you tried to turn off Wi-Fi after attaching the cable? The camera's behavior "... it was trying to set up a wireless connection..." suggests that the Wi-Fi was still on.
10-13-2014 02:25 PM
i did use the wifi early in the day when it happed but i turned it off at the event. the staius did say it say it was off.
the synic trouble came 4 hours later
