Canon EOS 70D giving garbeled photos
RichV
My new Canon EOS 70D is giving didital garbeled photos. This happens for ~1/20 photos I've taken. Odd thing about this the preview just after taking a "bad" shot looked OK/normal only after reviewing later on the camera or downloading did the distorted image appear.  Oddly if I save a bad pic to my desktop the thumbnail icon photo looks OK
Photo details: 5472 x 3648 pix jpeg
Before I contact Canon is this a know problem with a simple fix?
Peter
Low level format your sd card and change your way to transfer your pictures from the camera to the computer. If the pictures look good in the camera and you can zoom it in the problem is in the transferring process.
6 REPLIES 6
Peter
Peter
The bad photos either look bad when viewed on the camera or they show only a thumbnail with the message "cannot playback image" in the camera display.
This is not a data transfer issue, it's a camera/card issue.
Should I try to reformat the card?
Thanks
Sounds like a card issue.  Try reformatting the card in the menu on the camera, not with the computer.  Try another card if that doesn't help, but remember to first format the new card in the camera with the menu.
Scott
Peter
So then you will need to do as ScottyP wrote. Don't forget to low level format. Not just format. If I understand it correct, a low level format in the camera removes/hides the bad sectors at the card.
"This is not a data transfer issue, it's a camera/card issue."
You are correct it is not.
"Should I try to reformat the card?"
I would get a new high quality SD (Lexar, Sandisk, etc) card and format it in the camera.  Try again to see if everything is OK.
I did a low level format on the card and then took ~ 50 photos. All look OK, no digital artifacts/scrambeling. Looks like this worked.
Thanks all for your help
Rich
