08-20-2015 08:25 AM - edited 12-11-2017 01:58 PM
08-20-2015 09:45 AM
All I can say is Wow!
@EvrenDumanoglu wrote:
My question is;
What should be my camera setting for interior. . .
Thank you
Evren Dumanoglu
Photographer
My suggestion would be to hire an actual photographer to train you.Short of that, try the Green A+ intellegent auto mode.
08-20-2015 09:55 AM
08-20-2015 10:06 AM
I think there was misunderstanding... i am photographer as well but only for commercial product photography.
Im asking not for photography skills. Im asking best shot with Canon 6D camera. I know how its exact photoshoot settings ( my setting was ISO 400 - f/20 - 1.3 sec) and i tried with ISO 100 as well.
But issue is, photographs are not too much clear. There is grain. I need to know what is wrong on my settings? You got my point TTMartin?
Summary: all i need to know device settings not for iso, shutter speed etc settings...
I hope it was clear and you can answer me more kind...
Thanks
f/20 is too small of an aperture. At that aperture diffraction starts to come into play and reduces the overall sharpness of the photo. I would see if f/11 gives you enough depth of field. And f/16 should be your absolute smallest aperture.
Grain really shouldn't have been an issue at those ISOs. Looking at digital photos on a computer leads to over zooming or 'pixel peeping'. My suggestion would be to get some prints made from those photos so you can evaluate them more realistically.
08-20-2015 10:09 AM - edited 08-20-2015 10:09 AM
I see..Thank you for your suggestion...
Last question, if grain is still there is on print document, is problem on camera or lens?
Do you have any idea?
Thanks
08-20-2015 10:43 AM
@EvrenDumanoglu wrote:I see..Thank you for your suggestion...
Thanks
What post processing software are you using?
Or are you using straight out of the camera JPGs?
If you are using JPGs what picture style are you using?
Grain doesn't really indicate a problem with either the camera or the lens, it is more a function of post process (in camera or on a computer). Oversharpening can create 'grain'.
08-20-2015 11:09 AM
It would help folks help you if you post an image that shows the issue you are concerned about.
08-20-2015 11:11 AM - edited 08-20-2015 11:42 AM
Thanks
The key to avid adding 'grain' in Lightroom, is to avoid sharpening smooth areas.
No sharpening (400% view)
Over sharpening (400% view)
One way to avoid this is to apply a heavy sharpening mask in Lightroom so you don't sharpen even areas.
Sharpening mask set at 70
By pressing and holding the 'ALT' key, while moving the slider you can see what is being masked.
Black areas will not be sharpened.
Smooth unsharpened bokeh.
08-21-2015 09:13 AM
08-22-2015 12:40 AM
You also mentioned the "spotlighting" in the showroom. Depending upon what type of lighting it is, you may have problems.
If it's halogen or tungsten, set a custom white balance. There are neat targets available for this purpose (Lastolite EZ Balance are some I use), but even a plain white piece of paper or a "gray card" would be adequate.
If it's fluorescent (or sodium vapor or mercury vapor, which are unlikely), also set a custom white balance, but don't be surprised if some of your shots have color casts and/or exposure issues. These types of lighting cycle on and off 120 times a second, which our eyes don't see but our cameras might. It messes with both the color of light and the level of exposure. Nothing can be done about it (some of the newer Canon models try to deal with it using a Flicker Free technology, but the 6D doesn't). Just take plenty of extra shots and check them as best you can during the shoot, to be sure to get what you need with these types of lights.
You also could use flash, but that will introduce another color of light if it's mixed with the ambient lighting. You either need to filter the flash or filter the ambient light, to try to make them match in color temp.
It might be easier to make long exposures and if you have some issues with shadows, either set up some fill lights using the same bulbs as the ambient lighting uses or use some large white foam core or cardboard to "bounce" some of the ambient light to fill the shadows.
I would certainly use a tripod, too. I'd also use f16 at the smallest (f11 would be better). Use hyperfocal distance to set your point of focus and check things using Depth of Field Preview and Live view, to be sure you have adequate depth of field.
Set an 800 or lower ISO and use a long shutter speed. If your exposure is 1 second or longer you can enable Long Exposure Noise Reduction on the camera, but need to be aware how it works. LENR only works with 1 second or longer exposures, and after your first exposure of the subject, the camera will take a second exposure of the same duration with the shutter closed. It uses this second "blank" exposure to identify the noise in the image, which it then subtracts from the first exposure. If you inadvertently (or deliberately) interrupt the second exposure before it's completed, the camera discards both it and the first shot. (Some people making long exposures with LENR enabled think the camera is going whacky and cancel the second exposure by turning the camera off or pulling the battery, then wonder where their first shot went.)
Yes, selective sharpening such as was mentioned earlier helps minimize the appearance of noise. The 6D is one of the most image noise-free cameras that Canon has ever made, so you might even be able to use higher ISOs. You also can do noise reduction. I do a little in Lightroom, but will also use a Noiseware Photoshop plug-in for especially high ISO shots... It's even possible to do NR in each separate color channel with it, if needed. Do any noise reduction before final sharpening of the image.
Sharpening is best done in steps. Do some in Lightroom, but tread lightly until you have done any cropping and sized the image for it's final use... then finish sharpening with the image magnified so you can watch for any artifacts or other issues that sharpening might cause.
It sounds as if you'll need to do some experimentation... but once you have it worked out, it will be faster to set up and shoot the second and subsequent times.
Alan Myers
San Jose, Calif., USA
FLICKR & EXPOSUREMANAGER
