09-28-2018 03:17 PM
I bought a 35mm (non-digital) camera in the late 1990´s, with various objectives (bayonet). Will the latter also fit the Canon EOS 500 digital series?
09-28-2018 03:20 PM
@boblalux wrote:I bought a 35mm (non-digital) camera in the late 1990´s, with various objectives (bayonet). Will the latter also fit the Canon EOS 500 digital series?
What is the model number of the 35mm camera? If it is an “EOS” body, then the lenses will fit.
09-28-2018
03:37 PM
05:02 PM
SamanthaW
7XXXXX7 . I think it is a EOS. There are red spots on the objectives.
Thanks
[Removed serial number per forum community guidelines]
09-28-2018
04:58 PM
05:02 PM
SamanthaW
@boblalux wrote:7XXXXX7 . I think it is a EOS. There are red spots on the objectives.
Thanks
That sounds like a serial number. Look at the front of the camera for a model number. Do you see the word “EOS”?
09-29-2018
01:40 AM
04:19 PM
Yes, EOS is written on the front (in fact, EOS 500). The model number is written underneath. Why it converted the middle numbers to X´s I can´´t understand. I wrote seven-0-two-[remainder of serial number removed as this could compromise user privacy] (I´ll try again: 7[XXXXX]7)
09-29-2018
08:25 AM
04:20 PM
@boblalux wrote:
Yes, EOS is written on the front (in fact, EOS 500). The model number is written underneath. Why it converted the middle numbers to X´s I can´´t understand. I wrote seven-0[...]
You're missing the point. The 7-digit number is the camera's serial number, not its model number. The moderators of this forum corrupted the number so that it wouldn't be displayed for the world to see. Their policy of doing that is based on the fact that serial numbers can be useful for tracking stolen goods; therefore it's a bad idea to publicize them for no good reason.
09-29-2018 10:44 AM
I am asking for the model number of the film camera, not the digital EOS 500 camera.
If you bought as new in 1998, then it is probably and EOS body. If you bought it used, it might not be an EOS body.
09-29-2018 01:25 PM
09-29-2018 04:10 PM
EOS 500 is a film camera which will take EF lenses. Does your EOS500 look like this one here ?
09-30-2018 02:07 AM
