01-03-2017 10:17 PM
Card formatting, manual sensor cleaning and much more is not possible. Any suggestion is grealtly appreciated except sending out to Canon which is quite a distant away... 🙂 thanks
01-04-2017 09:17 AM
No better idea than i can think of than letting the experts look it over.
I assume that you have checked your settings, and the LOCK switch position. You might try reprogramming the <LOCK> switch just to verify whether or not the LOCK function is working properly. I assume completely resetting the camera does not change anything, either.
01-04-2017 10:28 AM
Cycle the switch on the back of the camera a few times in case it's not connecting.
01-04-2017 10:41 AM
I just checked the manual for my 1D4 & Custom Function IV -10 may also be set wrong. I suspect both cameras have the same set of Custom Functions.
01-04-2017 08:30 PM
01-04-2017 08:28 PM
01-04-2017 08:34 PM
01-04-2017 09:49 PM
You can set the custom functions tethered to a computer.
01-04-2017 11:19 PM
01-05-2017 09:04 AM
USB Cable between the camera & computer and have the Canon software installed on the computer. Not sure of the exact name but EOS Utility ot EOS Window or something like that.
