06-27-2021 07:14 PM
Hello, my canon 5D mark iii keeps ending video recordings at various timed intervals between 5-15 seconds. The screen goes black and displays a yellow exclamation mark in a hexagon, with the message "Press start/stop button to activate movie shooting" it will also go right back to this screen a few seconds after I've pressed the button it tells me to. It's never the same amount of time, it varys between 5-15 seconds.
I have already tried:
-Checking to make sure my memory card wasn't full, as well as trying another memory card
-resetting the camera settings
-I generally use a Nikon lens with an adapter, but I have this issue with my canon brand kit lens as well
I'm uncertain what caused this, the only thing I've done different with the camera, was a I did press some buttons to see what they did (but after having re set the settings I don't see how that could be the problem.
And I recently downloaded the canon webcam extension to my computer, and used my camera as a webcam twice.
06-27-2021 09:10 PM
What exact memory card are you using? Brand, speed, etc.
What resolution, framerate and codec are you using for the recording?
I'm perhaps thinking that the card cannot handle the sustained writes and after the buffer is full, it has no choice but to stop recording.
06-27-2021 11:09 PM
Here I'll attach photos of my memory card, as well as the settings for the video recording.
the thing is, that this is even happening when I'm not recording. I'll press the button and it will give me a screen allowing me to see what the lens is seeing for only a few seconds (again never the same interval of time) then it gives me that black screen with the message again.
06-27-2021 11:23 PM
The use of a micro SD card with an adaptor is likely the problem. Try using a quality full size SD card.
06-27-2021 11:26 PM
I've been using this sd card with the camera for months and I haven't had this issue, and the issue persist even when I take the card out (the camera changes from the lens view to that black screen with the message after only a few seconds)
06-27-2021 11:33 PM
Try another SD card, yours might be bad.
06-27-2021 11:47 PM
Or, if you'd prefer, please send the camera into our Factory Service Center to be evaluated. From there, they'll provide you with a detailed repair estimate. You will then have the option to move forward with the repair or reject it and have your camera sent back to you. You can set that process up now at: http://usa.canon.com/repair If you would like to speak with our technical support before sending the camera in, you can reach them Monday-Friday: 9:00 am to 9:00 pm ET, Saturday: 9:00 am to 7:00 pm ET at: 1-800-OK-CANON (1-800-652-2666). Thank you for contacting us.
