04-01-2021 01:19 PM
Hi everyone,
I used the SD card on my R6 and then on my 6D Mark ii. When I tried to import new photos taken on 6D into Lightroom, none of the new pictures taken on 6D shows up. Lightroom only shows photos taken on my R6. Weird thing is that I am sure I formated the card (old photos on my R6) before using the card on my 6D but all the old photos (taken on R6) are still there when import into Lightroom, but none of the photos taken on 6D.
How can I import the photos on taken on my 6D into Lightroom? I can view photos on my 6D just fine, it just didn't show up when trying to import into Lightroom. Is there anything that I do wrong?
Please help.
Thanks,
Khoi.
04-01-2021 01:41 PM
Are these RAW or JPEG? If RAW, is your version of LightRoom up to date so that it understands the R6 RAW format?
04-01-2021 06:23 PM
These are all RAW files. However, one is CR2 and the other is CR3. I'm not sure if that causes the problem. Thanks.
04-02-2021 09:09 AM
@khoihuynh wrote:Hi everyone,
Please help.
Thanks,
Khoi.
Are you copying the images onto your computer and then trying to import into LR or are you connecting the camera to the computer.
04-02-2021 10:06 AM
@khoihuynh,
You are setting yourself up for complications and grief. .CR2, .CR3
Using same card on cameras that save in different file types... Format the card in the body you intend to capture photos on. Use separate cards. if you don't you will eventually suffer some sort of data loss. Might not be today, but like gambling, the odds are against you.
SD Cards are cheap.
Simplify your life.
04-02-2021 01:34 PM
04-02-2021 01:35 PM
