Can't get my Canon 80d to sync with my Neewer external flash set up
cadiz
So I recently purchased the Neewer NW-561 Flash Speedlite kit for my Canon EOS 80D camera. it seems to connect well, because everything flashes together as it should. However , when i go to the flash control settings , and then go to external flash function settings , I get a  message saying , "This menu cannot be displayed. Incompatible flash or flash's power is turned off." Also I dont see the results from the flash in my photos. Is my camera incompatible or is it a setting or something i'm missing? Can someone help!!!!!!!!!!!!!!!!!!!
6 REPLIES 6
kvbarkley
VIP
This sounds like a question for Newer. If you are in TTL mode, it seems like you are getting the pre-flash, but not the main flash. Try in manual mode.
If  you really want compatibility, I would suggest you get a Canon flash.
Teeblue98
Im having this exact problem. Did you ever solve this?
normadel
Mentor
A very quick search of this flash points out clearly that this flash does not support camera menu settings.
That is because this is a COMPLETELY MANUAL flash. It does not communicate with cameras. It only flashes!
Thanks mate but I got it working. Works perfectly with the 80d. Just has to be through viewfinder rather then the monitor. 👌
It will work using the rear screen LiveView display, but first you will need to go into the LiveView menu and disable LiveView “Silent Shooting” which is set by default.
Mike Sowsun
amazing!!!! Thanks so much mate just done that. Mike you absolute legend
03/28/2023: New firmware version 1.0.3.1 is available for EOS-R5 C
03/14/2023: New firmware version 1.8.1 is available for EOS R6
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.0
01/18/2023: New firmware version 1.1.1 is available for EOS R6 Mark II
11/22/2022: New firmware available for EOS R3, EOS R7 and EOS R10
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
