02-17-2026
05:58 AM
09:06 AM
I need some helping ideas as I can't connect my EOS 1D with Utility 3 by using a MAC running on Tahoe 26.2
Utility 3 simply does not see my camera and I have no idea how to download pics now. Any ideas aer welcome.
Regards,
Ralph
02-17-2026 06:04 AM
A card reader plugged into a USB port would be best.
I have not used that camera, but it might work to connect the camera to the computer using a USB cable and use the "Image Capture" app that comes with macOS.
02-17-2026 06:04 AM
02-17-2026 06:17 AM
A card read should work. The LAN and the USB connection both did not work. When using the LAN connection I can see my camera in the Network connected but EOS Utility 3 does not care. The USB seems not see the camera at all. Thanks for the reader idea. Regards, Ralph
02-17-2026 08:54 AM
I haven't used the EOS Utility for quite a while. The current version of EOS Utility no longer includes EOS Utility2 which is the version that supported your 1D.
Here is a current list of supported cameras:
Canon : Product Manual : EOS Utility : Compatible Cameras https://share.google/897DiTBla4eeetIRv
Since the camera is approximately 25 years old, it's also possible that it will not be detected by connecting it to a PC or Mac running a more modern OS. A card reader recommended by @johnrmoyer is your best option.
02-17-2026 09:46 AM
Regards,
Ralph
Some early versions of EOSU3 (like 3.13.and earlier) will download and install EOSU3 and EOSU2. But EOSU2 won't execute on macOS26.
Best bet is either a card reader or using Apple Image Capture.
02-17-2026 10:33 AM
You know I haven't pulled my 1D out in a while but I don't remember a USB port on it. It has Firewire but no USB.
Get a CF card reader.
02-17-2026 11:19 AM
Thanks everybody for the helpful ideas and infos !!
05-05-2026 06:34 PM
MY mac26 says Eos utility3 will not be supported. Curious if Canon will come out with anything to replace it.
05-05-2026 08:28 PM
What is the exact error message. My MacBook with macOS 26 executes EOSU3 fine.
05-05-2026 09:37 PM
It has been a pop up that has come up twice. and goes away before I can copy it. Its like its created with a Microsoft program that won't be compatible.
