07-25-2016 12:36 PM
I bought my first DSLR camera just a couple of weeks ago, it's a Canon EOS 1200D. Yesterday I was fiddling around with some of the settings to see what they did, and now the camera won't focus at all.
The lens is the standard 18 - 55mm lens that came with it, and it won't focus at at either on manual or auto focus mode. It's a bright sunny day with no low light issues, so that's not the problem. It just won't focus at all. I have tried resetting it but that hasn't helped.
Any suggestions as to what I might have done, what might have gone wrong, what I could do to fix it would be very welcome. Bear in mind that I know very little about DSLRs at this stage. Many thanks.
07-26-2016 11:39 AM
Waddizzle wrote:
kvbarkley wrote:Where is there a manual focus setting in the camera?
"The lens is the standard 18 - 55mm lens that came with it, and it won't focus at at either on manual or auto focus mode."
I am fairly certain that the OP fully understands the significance of the AF/MF lens switch.
Probably. But he wouldn't be the only OP who didn't. I remember one that didn't know the difference between manual focus and manual exposure.
07-26-2016 03:47 PM
@RobertTheFat wrote:@Waddizzle wrote:
@kvbarkley wrote:Where is there a manual focus setting in the camera?
He knows enough about lenses to recognize that the 18-55mm is the standard kit lens.
12-06-2017 01:06 AM
08-28-2020 07:26 PM - edited 08-28-2020 07:28 PM
I just did this same thing and I was freaking out because I have a shoot to do tomorrow so I hope my info helps. I need everything broken down to me so I hope you don't mind the step by step instructions.
Go to the menu button on the top left side
Go to the Function setting tab and click on it
Go to the 4th tab and click on Custom Functions (C.Fn)
Tab over with your AF button to get to # 12
#12C.FnIV: Operation/Others Shutter/AE lock button
Choose the first option 0
0:AF/AE lock
Once you click on it it will unlock your autofocus.
Good luck
Reba 😃
09-29-2020 04:47 PM
09-29-2020 06:52 PM
You say you're MF isn't working. That is something you do by twisting a ring on the lens & if it doesn't have any effect then my guess is a damaged lens component inside the lens. You should see changes to the focus as you twist the ring from 1 end of it's travel to the other. At some point in between the end stops if should focus on your target.
09-29-2020 07:24 PM
Which lens?
