01-31-2019 10:57 PM
01-31-2019 11:32 PM - edited 01-31-2019 11:47 PM
Can’t you just put the GP-E2 in the hot shoe and use it without a USB cable?
If you want to use a cable you would need a USB-C to mini-USB cable.
02-01-2019 07:41 AM
Thanks,
I bought this unit used without the cords. And if you want to use flash, you have to get the GP-E2 off the hotshoe.
JGP
02-10-2019 03:07 PM
The port on the side of the GP-E2 looks a bit odd. I wanted to download the GPS logs and even though I have the cables that came with the GP-E2 (I'm the original purchaser), it doesn't come with anything that plugs it into a computer. I phoned Canon support and they told me to just use any USB cable that has a mini-USB end. They designed that wierd looking port on the GP-E2 so that in addition to their own proprietary connector ... a standard USB mini cable will fit (and work).
The cords that came with the GP-E2 (there are two) have a USB mini on one end, and the other end has the proprietary port. They included both a "short" cable (the 7D could use the GP-E2 but only via the USB port .. not via the hot-shoe) and the other is identical but a much longer cable (if you want to attach the GPS somewhere else other than on the camera.
SOMETIMES you can call the Canon "parts" department. The cables are NOT sold as "accessories", but you can probably order them as "replacement parts" by going through the parts deparment instead (I had the same issue with the 60Da ... there's a cable that lets you use Canon's TC-80N3 intervalometer with a Canon 60Da (which has a different type of plug) and they don't sell that cable as an accessory ... but they DID sell it as a replacement part via the parts department.
08-08-2019 11:39 AM - edited 08-08-2019 11:40 AM
I attach mine directly to the hot shoe on my R since I rarely use flash outside.
I have the Canon "off camera" cable but it too only has one hot shoe.
3rd party off camera cables have two hot shoes:
I have not personly tried this cable... but it should work and Amazon handles returns very well if it doesn't.
