Blown out pictures
rql49
I have a canon 4ti. When it is in auto mode or any other mode the pictures are over exposed. In the other modes I have to adjust the to have it under exposed by 2 or 3 stops. Any suggestions on how to fix it? I have cleared all the functions.
18 REPLIES 18
rql49
So how do i get the pictures to not be washed out.
rql49
Still washed out
No photo come out normal, properly exposed?  No, your camera is broken, sorry. Smiley Sad
Call Canon support.  Keep in mind a used "working" T4i is worth about $250.  That does not leave much room for repair if repair is even possible on a T4i.  It may be out of service life.
rql49
Thanks, I figured the camera is broker. I thought i would try and see if i missed something.
You're not addicted to fill flash, are you? One very effective way to achieve gross overexposure is to use flash in a scene so brightly lit that it needs a shutter speed faster than the sync speed. In such a circumstance, the camera won't use such a speed, even if you tell it to. (At least that's how it worked on an XTi when it happened to me; I've never used a T4i, but I suspect its behavior is the same.)
Bob
rql49
I just used the live view on the screen and it took a normal picture that wasn't blown out.
So it is the exposure system that is linked to the viewfinder. The camera needs repair.
It would be very bright indeed to prevent a correct exposure. My T6S can reach EV 23 and according to wikipedia, sand and snow in sunlight is EV 14.
Avatar
