02-09-2017 06:01 PM
02-09-2017 06:20 PM
(replace the fuse?) If you can see the shutter going then it is not that or the mirror.
The only thing to try is resetting the camera.
02-09-2017 07:09 PM
02-09-2017 07:33 PM
Yes, and there is often a menu setting to in the "wrench" menus to perform a reset. I assume the LCD works OK.
02-09-2017 07:36 PM
02-09-2017 07:36 PM
@bmwagner wrote:
The power board has a tiny fuse on it which was causing the camera to not power on at all. I basically went around it by using a wire soldered on both sides of it. By resetting do you mean to take out both batteries?
You bypassed the fuse? Not good. Fuses blow for good reasons. Whatever caused the fuse to blow, which the fuse circuit was designed to protect, has probably just burnt itself out. I suspect that you smoked it.
02-09-2017 07:37 PM
02-09-2017 07:40 PM
