11-16-2017 06:25 PM
11-16-2017 06:38 PM
Hello Welcome to the Canon Forums and thanks for your inquiry!
The EOS 1100D is known in the US by the name Rebel T3. This camera is compatible with the AC Adapter Kit ACK-E10. With the AC Adapter Kit you can power your camera by household power and not have to worry about the remaining battery power.
The operating voltage of the AC Adapter Kit/Compact Power Adapter/Battery Charger is 100V - 240V and conforms with international standards.
We hope this helps!
11-17-2017 02:42 AM
11-17-2017 07:53 AM - edited 11-17-2017 07:55 AM
That's not possible, no Canon DSLR will charge via the USB socket and there isn't an option to charge the battery whilst it is in the camera.
11-17-2017 09:55 AM
Ray-uk wrote:That's not possible, no Canon DSLR will charge via the USB socket and there isn't an option to charge the battery whilst it is in the camera.
And what difference does it make? Put the camera on the AC adapter and the battery in the charger. Problem solved.
11-17-2017 10:16 AM
I still need the camera too be hooked up to the computer and connected to EOS Utility at all time. It cannot be disconnected from the PC. That's why im looking for a way to either charge the battery while the camera is connected to the PC or find a way to run the camera on power directly from the computer
11-17-2017 10:41 AM
Selinmartin wrote:I still need the camera too be hooked up to the computer and connected to EOS Utility at all time. It cannot be disconnected from the PC. That's why im looking for a way to either charge the battery while the camera is connected to the PC or find a way to run the camera on power directly from the computer
The camera can run on an AC adapter while its battery is being charged. Why would that require it to be disconnected from the PC? To put it another way, the PC has no way of knowing, nor reason to care, that the camera isn't operating on its battery.
11-18-2017 08:44 AM
You have created a problem where none existed. Get the AC adapter. You already have the charger and perhaps buying a second battery could help. All common gear that most of us have.
You can not ask the camera and battery to do things it was never designed to do.
