08-05-2014 08:17 AM
Who has experience with off-brand battery grips for the 60D?
08-05-2014 12:20 PM
I've had three different cameras that used Canon grips -- never had a problem.
I've not personally owned a 3rd party grip. Every so often we get a post where someone has a problem with a camera which only manifests if their 3rd party grip is attached to the camera (often it doesn't even need to be powered on and in use... just having it connected can be enough) and the camera will start behaving in odd ways. They remove the grip and it's back to normal.
While I don't own a 3rd party grip, I suspect these grips must actually work for most of the users because major retailers such as B&H Photo and Adorama sell them and I doubt they'd sell them if they had a high return rate.
If you'd like to get a 3rd party grip anyway... just be mindful that it can even effect the on-camera control buttons if the grip is having a problem. If you have a problem, remove the grip entirely (don't just power it off) and re-test the camera.
08-05-2014 09:41 AM
I don't but I still don't advise it.
But I do have some knowledge of other off-brand grips. If you get a good one OK but there are lots of faulty ones.
And even counterfeit ones. Be safe and stick with Canon.
08-05-2014 11:35 AM
I am definitely in the other corner on off-brand grips. If you are not investing in equipment, making a purchase that you expect to be recovered in the sale of your photographic services, then you have every reason to try a grip made by a different manufacturer.
Just my $.02.
08-05-2014 12:20 PM
08-05-2014 12:27 PM
I ahve the 70D, and a Neewer brand grip. Other than the camera not reading the battery level right, it's a great grip for the price. I bought the grip on amazon for 45 i think, and then bought an extra charger w/ 2 batteries, both larger capacity in "maH" than the stock battery. My canon battery is my spare now, and shoot all day & all night w/ the pair in the grip. Canon grips would be ideal, but if not, I've been happy with my Neewer & Vivitar 2300 MaH (?) batteries.
08-06-2014 09:32 AM
"... the camera not reading the battery level right, ..."
It sounds like a pretty good rerasons to stick with genuine Canon accesssories. Messed up camea functions and not reading batteries?
08-06-2014 02:49 PM
I see a person who has not exercised their right to get a properly functioning accessory. Not a reason to "stick with.."something.
@ebiggs1 wrote:"... the camera not reading the battery level right, ..."
09-06-2014 12:30 PM
09-06-2014 06:17 PM
Good choice.
