06-29-2017 12:04 PM - edited 06-29-2017 12:05 PM
Hi everyone,
I have a canon 60D + 50 mm 1.4 canon lens.
I bought two of them ; but the focus of the lens ( Auto&manual) was not working because of barrel ring deformation.
So, I purchased the part from internet, manual focus works now perfectly. But, the autofocus does not give perfect results. If I zoom while autofocusing, the camera skip the perfect focus and stop focus on a blurry image.
So, what do you think ? could the problem be from the ring or the motor of the lens? and of course, I hope it's not a camera problem...
Thank you very much !
07-02-2017 11:16 AM
07-02-2017 11:58 AM
If you took your lens apart and made some sort of repair, you are on your own. I cannot advise you on what to do, and I don't believe many others around here can, either.
07-02-2017 01:01 PM
I suggest you mount the camera w/lens on a tripod when you are testing. Then take some pics in both AF and M/F modes and see the results. See if the pics taken with AF are blurry. Try step down to F2.8 and F4 and see the results.
You are holding the camera with your shaking hands and magnifying the view makes testing very unreliable.
Test it in a well lit enviroment with a target with good contrast.
In your video the first beep confirmation comes with an in-focus image. The second one comes with a blurry image. But it cannot proof anything.
If after proper set up, the lens still cannot focus accurately, send it to Canon. Or simply use it as a manual fcous lens.
07-03-2017 10:16 AM
07-03-2017 10:21 AM - edited 07-03-2017 10:52 AM
Even on a tripod it doesn't give perfect reuslts ..
I see that it's not a simple issue, so thank you very much and I aprreciate your help. .
Have a good day !
