09-24-2018 12:45 PM
Hello all!
So I recently purchased a EOS M50 and I really do like it as it's my first camera so entry level felt right. However, I hit a slight snag and instead of trying to back track on it, I'd like to make it work.
I purchased the DJI Ronin S stablizer. However, I learned that that stabilizer really favors heavier cameras so properly setting it up isn't working becaue it's too light.
I thought to add balance weights between the camera and mounting plate but I can't find any 1/4 screws that are long ehough and have the correct threading in order to do this.
So I'm looking for guidance / suggestions!
09-26-2018 06:59 PM
If you went to a workshop that does digital printing or cutting, you could get them to print a metal plate for you that fits the bottom of the camera, with holes for the various ports - e.b. threaded for a tripod and an opening for the battery. That is likely to keep the balance of the camera on the body rather than pushing the C of G forward with a heavy lens.
09-24-2018 12:48 PM
Also, I know if I got a bigger lens I would be able to balance it, but I'm looking to use some of my other lenses such as my 24MM and 50MM.
09-26-2018 06:59 PM
09-26-2018 09:25 PM
@Tronhard wrote:If you went to a workshop that does digital printing or cutting, you could get them to print a metal plate for you that fits the bottom of the camera, with holes for the various ports - e.b. threaded for a tripod and an opening for the battery. That is likely to keep the balance of the camera on the body rather than pushing the C of G forward with a heavy lens.
Note, though, that nothing that doesn't stiffen the front of the camera body will help to counteract the strain placed on the camera body by a heavy lens. Simply moving the CoG rearward will not do it. I recognize that that's not necessarily the issue in this case, but it's worth keeping in mind.
09-27-2018 04:01 PM
Perhaps a housebrick and a piece of gaffer tape might do it
09-27-2018 04:08 PM
09-27-2018 04:32 PM - edited 09-27-2018 04:55 PM
Absolutely agreed Bob. I would favour the plate solution rather than committing to a heavy lens. Not only would it put strain on the mount it would throw the CofG forward. A custom-made base plate for the body would seem to me to be the best solution. It's a pity there doesn't seem to be a battery grip for this body, that might have been a solution.
The closest I can find is the Really Right Stuff BCM5-L Set L-Plate for Canon EOS M5 - it would add about 50gm of weight, but we don't know how much weight is wanted...
09-27-2018 04:42 PM
I'm gonna look in to getting a custom base plate. I had a Roxant stabilizer and I tried to somehow mount the weights that it came with to the camera but I couldn't find a screw long enough to put all 3 weights plus the Ronin S base plate on. But this seems easy enough. Just get a base plate that would cover the rectangular portion of the bottom of the camera and make sure that it's heavy enough.
I appreciate everyones help!
09-28-2018 10:11 AM
@srivas285 wrote:I'm gonna look in to getting a custom base plate. I had a Roxant stabilizer and I tried to somehow mount the weights that it came with to the camera but I couldn't find a screw long enough to put all 3 weights plus the Ronin S base plate on. But this seems easy enough. Just get a base plate that would cover the rectangular portion of the bottom of the camera and make sure that it's heavy enough.
There is a name for a “custom base plate.” It is called a set of rails. Mount the camera on a set of 15mm rails.
