03-06-2022 11:15 PM
I have a modified EOS RP that I have been using for astrophotography. I have reading a lot on what DSLR settings would make the best images including Craig Stark (http://www.stark-labs.com/craig/resources/Articles-&-Reviews/CanonLinearity.pdf). Craig ran exposure experiments on his Rebel XSi with Digic III processor. He knows that Digic III changes the RAW image and concludes "The camera’s internal gain (e-/ADU) for each ISO value points toward limiting the ISO to 400 and not using higher values. Both in theory and in practice, using higher values limits the dynamic range and does not let you pull out fainter details from the noise (even if they look brighter)." I personally have been using 12800 ISO with no issues. However, I have only been shooting deep space objects for about a year, so I'm still learning. I'm concerned about introducing too much noise with the higher ISO. I'm wondering how much the Digic 8 processor changes the results of Craig's experiment, i.e. 400 ISO limit. Does anyone have experience with using the EOS RP in astrophotography and has optimized the settings?
03-07-2022 01:27 AM
@tstevens83 wrote: www.myindigocard.comI have a modified EOS RP that I have been using for astrophotography. I have reading a lot on what DSLR settings would make the best images including Craig Stark (http://www.stark-labs.com/craig/resources/Articles-&-Reviews/CanonLinearity.pdf). Craig ran exposure experiments on his Rebel XSi with Digic III processor. He knows that Digic III changes the RAW image and concludes "The camera’s internal gain (e-/ADU) for each ISO value points toward limiting the ISO to 400 and not using higher values. Both in theory and in practice, using higher values limits the dynamic range and does not let you pull out fainter details from the noise (even if they look brighter)." I personally have been using 12800 ISO with no issues. However, I have only been shooting deep space objects for about a year, so I'm still learning. I'm concerned about introducing too much noise with the higher ISO. I'm wondering how much the Digic 8 processor changes the results of Craig's experiment, i.e. 400 ISO limit. Does anyone have experience with using the EOS RP in astrophotography and has optimized the settings?
Use this setting
03-08-2022 02:11 AM - edited 03-08-2022 11:46 PM
@VWCredit wrote:I have a modified EOS RP that I have been using for astrophotography. I have reading a lot on what DSLR settings would make the best images including Craig Stark (http://www.stark-labs.com/craig/resources/Articles-&-Reviews/CanonLinearity.pdf). Craig ran exposure experiments on his Rebel XSi with Digic III processor. He knows that Digic III changes the RAW image and concludes "The camera’s internal gain (e-/ADU) for each ISO value points toward limiting the ISO to 400 and not using higher values. Both in theory and in practice, using higher values limits the dynamic range and does not let you pull out fainter details from the noise (even if they look brighter)." I personally have been using 12800 ISO with no issues. However, I have only been shooting deep space objects for about a year, so I'm still learning. I'm concerned about introducing too much noise with the higher ISO. I'm wondering how much the Digic 8 processor changes the results of Craig's experiment, i.e. 400 ISO limit. Does anyone have experience with using the EOS RP in astrophotography and has optimized the settings?
Use manual or bulb mode.
Use a “fast” aperture of F/2.8 – F/4.
Set your white balance setting to daylight or auto.
Set your exposure length to 15-30-seconds.
Shoot in RAW image format.
Use Manual Focus.
Use an ISO of 400-1600 (or more)
Use the 10-second delay drive mode.
02-02-2023 03:44 PM
I also have an astromodded RP. The first thing I noticed is that the sky is now pink. Alyn Wallace has an interesting video (https://www.youtube.com/watch?v=D6zSapztM4o&t=782s&ab_channel=AlynWallace) where he discusses this issue and suggests it can be corrected by using Custom White Balance. Another video (https://www.youtube.com/watch?v=RIztrabEKFc&ab_channel=HankTongho) explains how to do this. It involves taking a photo of a white surface. I used these 2 videos to eliminate the pinkness though it does seem to lower the red sensitivity which is why one mods in the first place.
I might add that I'm primarily interested in doing astro time-lapses, using the RP's automatic time-lapse mode. Typically I take 8 sec exposures every 10 secs, sometimes for 8 hours! Still lots to learn.
