07-14-2013 07:18 AM
08-02-2013 06:44 PM
08-02-2013 06:57 PM
Interesting. I have heard that Canon does not allow 3rd party flashes. I purchased a small SunPak fill flash, since the Mark III doesn't come with one. I used it once, and have not been able to get the AF selection mode to work since. Maybe the hotshoe of a 3rd party device shorts something out???
08-02-2013 07:19 PM
10-26-2013 08:39 AM
10-29-2013 02:40 PM
dsoup,
I finally called Canon Customer Support. We wound up reseting the C-Fn and Clearing all Camera settings (admittedly resulting in my having to spend a lot of time to reset...). But it did fix the issue. The panel on the top of the camera does not change via design, it only reflects SEL [ ] (and [ __ ] AF) . But the large LCD on the back of the camera does work.
If I press the INFO button on the back of the camera (3 times) to bring up the Settings menu (Av/P/Tv, Shutterspeed, Aperature, ISO, etc), then press the 3rd button on the right behiind the top panel (AF point selection button - looks like a square with 5 dots in it), it brings up the 6 AF selection modes on the back of the camera. Immediately pressing the M-Fn button (behind the shutter release) toggles through the selection points.
BTW, this didn't work at all until I reset everything. Go figure. It works now.
Hope that helps.
The Canon Cust Serv folks were extremely helpful. It may be worth a call into them.
10-29-2013 03:53 PM
09-20-2018 06:56 AM
Hello everyone.
I bumped into this problem some days ago. Only resetting camera settings (not custom functions) helped. I thought it would be useful to write this here.
Still no cue why the AF selection stopped working. I suspect connecting my camera to an Android tablet with DSLR Controller app, which might have messed up or locked the ability to choose AF points.
10-20-2018 11:48 PM
This is happening to me, M-Fn will not scroll / select the AF modes, i am stuck on single point? i reset everything as pointed in the thread and still no joy. i reset everything of this 5d3 to another one that does not have this problem . could it be a firmware issue, the problematic one is 1.2.3, its a used 5d3 with 43k actuations,
10-21-2018 12:23 AM
@cpstephens wrote:This is happening to me, M-Fn will not scroll / select the AF modes, i am stuck on single point? i reset everything as pointed in the thread and still no joy. i reset everything of this 5d3 to another one that does not have this problem . could it be a firmware issue, the problematic one is 1.2.3, its a used 5d3 with 43k actuations,
The 5D3 is now at 1.3.5, (At least that's where mine is.) So you might as well start by upgrading yours.
10-21-2018 12:47 AM
